Old 04-07-2005, 02:01 PM   #1
Purs
Got Big Block?
Purs's Avatar
How do I....
get my upper ball joint to let go of the spindle? I've got the lower one loose but the upper will not let go. I've beat on the flat parts of the spindle until I'm blue in the face. Then I've tried a pickel fork and it didn't work. Any help is appreciated.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 04-07-2005, 04:38 PM   #2
Putter
More Cowbell....
Putter's Avatar
Keep hitting it with the fork. It will just let go in due time. If you can get it to wedge in there, give it a good smack with a 6-lb sledge. Works every time!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-07-2005, 04:54 PM   #3
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Loosen the castle nut a few turns (leave enough thread engaged to retain the spindle).
Support the vehicle by the frame, and let the lower control arm hang down.
Whack on the spindle in the area where the ball joint passes through with your favorite hammer. 3lb usually works fine, shouldnt take more than a couple good hits.
The vibration from the hammer will loosen the ball joint, and the spring pressure will pop it loose.
Then raise the control arm with a floor jack, take off the castle nut continue disassembly. Lower the control arm slowly and watch out for that spring!
I usually bolt a piece of chain through the lower control arm and the spring, just in case. A compressed spring shooting out and hitting you in the face could really ruin a guy's day.
Chris H is offline   Reply With Quote
Old 04-07-2005, 04:55 PM   #4
PMS
Try using (2) 6-lb. sledges. Hold one sledge on one side of the ball joint and use second one and beat on the opposite side of ball joint. Sometimes they can be a bear - you just have to be a bigger bear...
PMS is offline   Reply With Quote
Old 04-07-2005, 04:58 PM   #5
OhioDan
OhioDan's Avatar
I've alway just loosened the nuts up until it's just even with the top of the ball joint threads. Put floor jack under a-arm. Smack with BFH on the side of the spindle, at the point where the ball joint goes thru the spindle. Spring tension will force them apart. Nuts still on will keep things from coming apart. Then, take nuts off, lower jack and let frame rest on jackstand. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 04-07-2005, 05:06 PM   #6
flip66
flip66's Avatar
I had the same problem I rented the pitman arm remover from auto zone and used it the thing came right off
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 04-07-2005, 05:13 PM   #7
Purs
Got Big Block?
Purs's Avatar
thanks for the input guys, maybe I wasn't clear. I've already been successful getting the lower ball joint loose from the control arm using the methods mentioned above, the spring is removed and the lower control arm is hanging out of the way. The problem is my pickle fork isn't creating enough of a wedge to force the ball joint away from the spindle. So I've been beating on the flat parts of the spindle where the tapered end of the ball joint passes through with no success. Looks like I'm going to get a really BFH and stay at it. Thanks to everyone again and now I'm off to the garage....
Old 04-07-2005, 06:34 PM   #8
72MARIO
72MARIO's Avatar
I cut a 1/4" shim to fit under my pickle fork. Worked for me.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-07-2005, 06:44 PM   #9
Gee_Emm
The 2 hammers at once is a good method.
Gee_Emm is offline   Reply With Quote
Old 04-07-2005, 06:56 PM   #10
Orange70chevy
Orange70chevy's Avatar
Try a pickle fork on a air hammer
Orange70chevy is offline   Reply With Quote
Old 04-07-2005, 08:23 PM   #11
Rollie396
someday it will be done!
Rollie396's Avatar
yup I built a pickle fork out of a chunk of 5/8"(iirc) plate and fit it to an air hammer.Worked like a charm.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 04-07-2005, 08:49 PM   #12
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
I had to use two pickle forks to get some of them to break before.
pebbleboy is offline   Reply With Quote
Old 04-07-2005, 11:12 PM   #13
Purs
Got Big Block?
Purs's Avatar
got it! The spacer idea got me thinking, I grabbed a 13/16 wrench and put it around the ball joint like a spacer, then the pickle fork and BAM! it popped right off. thanks to everyone for the brainstormin'
