No,I DON'T have Tourett's
Bracket connection @ top and windshield frame
One of my top/windshield connections is just a gaping hole in the windshield frame......obviously the backing nut is gone........any ideas how to fix?
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
SKINNY TIRES RULE!
Can you weld in a new nut?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
I got that problem too. When I get to it, I'll take the windshield out and weld a nut in place. I'd be interested if anyone has other ideas.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
You try a threadsert.
I've got one of these kits and they work excellent. http://www.nutty.com/threatsert.html
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Well........the windshield does need replaced, perhaps when I do that I can tack a nut in there. That threadsert might work for now. Must kinda be like a wall anchor? Is it reuseable ie. the bolt can be removed and reinstalled bobbyk?
What the thread-sert does is become a threaded sleeve the bolt threads into.
It fastens like a rivit,sandwiching the metal between the thread-sert head and the bottom of the thread-sert that's pulled up. The wall of the thread-sert collapses at a designed point.
gotcha........ok thanks for the info
Just need a couple more parts.
How did it work?
I have the same problem with as one of the backing nuts is missing.
How did you end up fixing the problem?
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
Drill a small hole on each side of the existing hole.
Grind the top side and bottom side of the proper sized nut enough so it will slide through the hole. You may also need to shape your hole to the appropriate shape to get the nut through it (make it oval shaped). tack weld some welding wire to the face of the nut and push it into the shaped hole while using the wire as a "handle". Carefully bend the wire so that the nut is flush with the hole and spot weld it through the 2 holes drilled in step 1. Fill in any sheet metal that was cut away to get the nut behind it with weld. grind/sand/paint.
![]() They are not "insurgents"...they're vermin, cowards, and terrorists. Egon..." I think that they are more interested in my epipedimus." |
#10 | |
GO VOLS!
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
Haven't got around to doing mine yet. Is the threadsert/nutsert a re-useable, ie the bolt can be removed and reinstalled?
#12 | |
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
