06-08-2002, 11:20 PM | #1 |
stock rear ratio
I'm just curious about the rear end in my trucks.. I have two '70 half tons.. One is a longbed that came with a 350/t350, and the other was a 307/3spd manual. Neither have a ratio on the option sheet. Would it be safe to assume they are both peg-legged 3.73s? I also have a 68 with a 250/3spd that I know for a fact has a 3.73. I know the best way to check is to pop the rear end cover and count the teeth, but I would like to know what to expect. Thanks.
Milan 1964 Chevelle SS 283/M20 |
06-08-2002, 11:31 PM | #2 |
Look on top the passenger side axle tube for a 3 letter code stamped into the tube. Then post the codes.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
06-08-2002, 11:38 PM | #3 |
its all about the +6 inches
I'll say the 350/350 is a 3.07...not sure about teh stick truck.
The oil needs chainged in there anyways. |
06-08-2002, 11:49 PM | #4 |
[]D [] []v[] []D
what about
a 72 1/2 ton 2wheel drive lngbed wth a 307/350 turbo (auto) with the stok rearend???
Clint 72 c'10 350ci/400hp sleeper forever |
06-09-2002, 12:04 AM | #5 |
If not mistaken,(And someone please correct me if I am mistaken) all small block automatic 1/2 ton trucks came with 3.07's as base equipment.
06-09-2002, 07:32 AM | #6 |
I believe if you raise one wheel and mark the yoke, then turn the wheel (tire) two full turns while your counting the revolutions on the yoke that'll give you ratio. If the yoke turns just over 3 times it's a 3.07, if 3 3/4 it's a 3.73 and so on.
Fayette Alabama |
06-09-2002, 11:52 AM | #7 |
longhornmail is right. The factory spec the 350/350 with a 3.07 as standard
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
