Old 04-07-2005, 06:32 PM   #1
72MARIO
72MARIO's Avatar
Do I need a neutral safety switch?
I am just finishing installing my Van tilt. I went to hook up the netural safety switch and there are no wires to hook up to it I did relocate the switch also. I switched my truck from a 3 on the tree so I guess standard truck don't have a safety switch ? I have the plug for the reverse lights but nothing for the ignition. Would the switch be in the purple wire ? Is it possible to wire it into my harness ? I really don't want to pull it I just finished getting everything hooked up.
Any help would be great.
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-07-2005, 06:35 PM   #2
71swb4x4
71swb4x4's Avatar
If you have an auto you will want the neutral safety switch. You may need to get a harness from an auto truck - but I am sure someone can tell you how to wire it into your existing harness.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-07-2005, 06:37 PM   #3
jhow66
jhow66's Avatar
Just find large purple wire from switch and cut. One side of cut to n. s. switch-the other side of cut to other side of n.s. switch.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-07-2005, 08:00 PM   #4
junkyardjohn
junkyardjohn's Avatar
STICK SHIFT TRUCKS DO NOT HAVE A NUETRAL SAFTY SWITCH. DO YOU HAVE TO HAVE ONE WITH YOURE NEW AUTOMATIC TRANS.?? NO BUT YOU'RE TRUCK WILL START IN GEAR NOW. I BYPASSED THE N/S SWITCH IN MY BLAZER, SIMPLY BECAUSE I'M THE ONLY ONE WHO EVER DRIVES IT, & I LIKE BEING ABLE TO START IT IN ANY GEAR. IT'S VERY HANDY IF YOU'RE TRUCK EVER STALLS IN TRAFFIC, & INSTEAD OF STOPPING & PUTTING YOUR TRUCK IN PARK OR NUETRAL, YOU JUST HIT THE KEY. IT'S A SAFTY THING, PUT THERE FOR YOUR OWN GOOD. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 04-07-2005, 09:54 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I bypassed mine too.
I know I ain't bumb enough to park it in drive, so that means it won't be in drive when I get in to start it.
Right?
