04-07-2005, 07:29 PM | #1 |
C10 Club Tennessee
Difference b/t 50 series and 60 series tires?
I'm doing a 4/6 drop I have 17 inch wheels that came with 235/50's on them. They are in prett good shape so I want to use them. I wanted to go with 275/50's like most of the guys here I see with at 4/6 drop. I have an opportunity to get some 275/60's I wanted to know the difference it will make. I will eventually go with 255 up front, but I didn't want to waste these 235's.
thanks
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
04-07-2005, 08:05 PM | #2 |
Are they 235's or 275's? (the one's you're thinking about)
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
04-07-2005, 10:13 PM | #3 |
C10 Club Tennessee
They are 275's-they are for the rear. I was going to try to run the 2 best 235's that I already have on the front and then get 275's for the rear.
04-08-2005, 01:39 AM | #4 |
C10 Club Tennessee
ttt
04-08-2005, 08:45 AM | #5 |
Smell that burnin' rubber
Yellow, I've got a similar dilemma. Here's what I've come up with so far.
Combo 1: F-255/50/17 (27"T) , R-275/50/17 (28"T) Combo 2: F-255/60/17 (29"T) , R-275/60/17 (30"T) IMHO, Combo 1 looks good and is commonly used by members on this board with a 4/6 drop. Combo 2 gives much more wheel house fill and is what ECE recommended to me. Take a look at ECE'e Project 68 pics to see combo2. However, their drop is 4.5/4. They assured me that I wouyld have no interference problems with a 4/6 and the proper BS. Combo 2 doesn't give the same visual "dropped" apperance as combo 1. |
04-08-2005, 12:33 PM | #6 |
C10 Club Tennessee
So the 60 series will fill the wheel well more? I know the 60 series are a little cheaper and easier to come by.
04-08-2005, 02:07 PM | #7 |
Mike
Yes the 60 series is taller.70 series is taller than 60.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
04-08-2005, 02:13 PM | #8 |
71 DELUX
235/50's sound to me as if they'd have REALLY short sidewalls. I have 235/60/15's on the front of mine with 295/50/15's out back. The sidewall height is almost identical, with the rear being only slightly taller.
275/60's are very popular on these trucks and usually quite affordable. I had those on mine when I bought it, one at each corner...but wanted a different look. Also, they rubbed just a tad up front with the drop I have.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
04-08-2005, 03:00 PM | #9 |
It's a catastrophic success.
04-08-2005, 03:22 PM | #10 |
Most major tire retailers have a fitment/size chart on their web sites.
04-08-2005, 04:17 PM | #11 |
Tires are sized by what is called an aspect ratio. For example 295/50/15 is broken down to 295 millimeters wide and is 50% as tall as it is wide. Therefore the sidewall height would be 147.5 millimeters high I am not sure what that works out to in inches because I cannot find my conversion chart.
2004 Extended cab LS silverado 2001 Buick Lesabre 1968 Chevy Custom 10 LWB Anniversery model 2008 crew cab lt (rolling on dubs) "The nice part about living in a small town is when you don't know what you're doing, someone else always does" |
04-08-2005, 04:42 PM | #12 | |
A 235/50/17 tire is only 26.3" tall and will likely look a bit small, especially in the rear. Last edited by Dual quad; 04-08-2005 at 04:48 PM. |
04-09-2005, 12:06 AM | #13 |
C10 Club Tennessee
I'm only putting the 235/50's up front at first because I already have 3 good ones out of my four tires. I really am trying to figure out what to put on the rear.
04-09-2005, 03:25 AM | #14 |
wheels
Hey I have 17's with 255/60/17 frt- 285/60/17 rear. No drop yet but I will have room to drop, 17x9.5 rear w/5.5bs, 17x8 frt. w/4bs. Here what it looks like know. And this is close to what I want it to look like.
72 C-10 |
04-09-2005, 03:50 AM | #15 |
Saving 1 truck at a time!
235 50 17 9.25 inch wide x 26.25 inch diameter
255 50 17 10.04 inch wide x 27.04 inch diameter 275 50 17 10.83 inch wide x 27.83 inch diameter 275 60 17 10.83 inch wide x 29.99 inch diameter
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
04-09-2005, 09:21 AM | #16 | |
computer illiterate
this is exactly right
72 2wd blazer 72 swb 4x4 |
04-09-2005, 09:22 AM | #17 |
Lamer, nice truck. Are those TT2's? Is the bottom pic a photoshop or actual drop?
04-19-2005, 03:06 PM | #18 |
Got Big Block?
photoshop on the bottom.
"Experience is what you get when you didn't get what you wanted." |
