Old 04-07-2005, 11:26 PM   #1
jetfixr
Braided heater hose
OK, OK.... I know braided lines are unnecessary and expensive as hell, but I really like the way they dress up the engine compartment. My fuel lines and tranny cooling lines are stainless, now I want to tackle the heater hoses. I believe one is 5/8 and the other is 3/4. I can find NPT to AN adaptors for the water pump and manifold, the part I am having problems with is where it enters the heater core at the cab. The heater core has just a standard hose barbs on it. I would rather not use one of those cheesy dress up kits with the standard hose clamp having a fake anodized fitting over the top of it. Do they make a heater core with An fittings on it? Anyone have any ideas?
jetfixr is offline   Reply With Quote
Old 04-08-2005, 11:53 AM   #2
Bowtiefreak
Bowtiefreak's Avatar
Most of the major brands out there have adapters for this BUT those are only available in a weld on style. I am not positive but I am pretty sure that you can adapt it with a tube nut adapter. You would cut the heater core tubes, flare it to 37 Deg, and add the correct nut and adapter.
I wouls suggest calling Russel,Aeroquip or Earls directly.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 04-08-2005, 12:22 PM   #3
Low69CST
Howabout cutting the tubes off the heater core at the tank and having a NPT bung welded on, like a racing radiator has. Then run a short hose up through the A/C box, then a AN coupler in the engine compartment, where the hose is usually attached. Run from there to your motor. I've been wanting to do the same thing to my truck. Would probably need to talk to a radiator shop to find out for sure.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-08-2005, 05:00 PM   #4
franko72
Franko72
franko72's Avatar
We buy stainless braided hoses at the place where I work. This guy can hook you up.
Hank Zawada 277 Adena Trace Ackron , OH 4432 Phone (330) 665-1832
They specialize in many different types of braided hoses and can fabricate whatever you want
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 04-10-2005, 10:25 AM   #5
jetfixr
Right on... thanks for the input guys.
