How in the heck do you remove the light switch so I can remove the instrument cluster?
Reach up under the dash to the top of the light switch, there is a spring loaded button on top of the switch, you have to push it down and pull the switch button out.
1971 Chevy SWB Oklahoma City, Oklahoma |
Half a bubble off!
Reach up in behind the dash and feel for a release button on top of the swith housing. This button will release the stem and knob so that you can pull that out of the way, and the rest you will see.
------------------[*]'71 Cheyenne, 402BB[*]Winfield, KS[*] http://barn9.freeservers.com[*] steer50@hotmail.com
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
don't forget that the lights will be in the on position
either unplug the switch or disconnect the battery
70 3/4 ton 4x4 FOR SALE Greene, IA |
Old member
If you turn the knob all the way to the left it will unscrew itself, but it was glued from the factory, I have never done this reaching up under the dash deal. It does work I'm sure but a lot of trouble to get to. I also put new knobs on my 71 that have set screw in them also though.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 http://geocities.com/chevy71tpi/main.html http://www.picturetrail.com/Andy4639
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
