04-08-2005, 09:52 AM | #1 |
Red
Vac. leak...... I think
I think I have a power brake booster leak and have a few Q's. There is a hissing sound near the booster, and when I pinch the boosters' vac. hose with channel locks, theengine idle changes.
I was planning to replace the power booster but how do I know if the Master cylinder needs replacing also? COuld the MC and not the booster be the problem? Can the booster be replaced without removing the MC (i.e. unbolt the MC to booster bolts and slip out the booster, or does the MC need to be disconnected from its' brake lines and removed also). Any gaskets or seals between the MC and booster that don't usually come with a new booster? Mike
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). |
04-08-2005, 11:20 AM | #2 |
Mike
Yes there is enough room to remove the mc without taking the lines off.Is the vac hose in good shape and tight?Make sure.The booster should hold vac even after the truck has been off for a while.Build some vac up and turn it off.Pull the fitting out of the booster after 5 min,see if the is any vac.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
04-08-2005, 12:14 PM | #3 |
Red
Yea, new vac. line and on there good. I replaced it when I was looking for a reason my truck was runnung bad. Turns out engine is terminally wounded and crate engine is on it's way.
WHen you check for vac. after shutting the truck off, like you mentioned above,should you hear a sound if it's holding vac? Sucking sound when you remove the fitting?
04-08-2005, 01:38 PM | #4 |
Mike
Yes,You will hear a sucking sound.
04-08-2005, 01:50 PM | #5 |
No,I DON'T have Tourett's
I just replaced the master cylinder on my truck, there is a gasket between it and the booster. NAPA said they didn't have a precut gasket for it, but gave me a sheet of material to make my own.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
04-08-2005, 03:34 PM | #6 |
Red
blazerparts/
Do you remember seeing or replacing a rubber "master cylinder push rod seal" or "cup seal" on yours? I seem to remember reading a post a few weeks ago when I first thought about changing the booster that mentioned that. Where would you get one of those if it is torn? I'm trying to anticipate things before hand. THanks
