63 Disc Convertion
I have a totaled 72 C10 with disc up front. I have a friend that like to try and put the disc set up off the 72 on his 63. Has any one ever tried this and will it work if so hard is it.
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi Last edited by flip66; 04-08-2005 at 11:47 AM. |
transfer the whole crossmember and steering and it will work fine.almost a bolt in.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
disk brake conversion
It is a bolt in mod, make sure you get everything from the '72. You might have to drill a couple of extra holes for the Xmember, and you will have to do a few mods on the firewall for the brake booster. You will also split your brake lines in two seperate systems. Don't forget to buy the bleeder tool for the proportioning valve, so you can bleed the brakes. DO NOT bolt the steering box to the frame, make sure you get an adapter plate (REZ engineering sells one).
