Old 04-08-2005, 01:17 PM   #1
Nima
Blue 67
How to adjust this door?
Hey guys/girls:
I am still working on interior!. Slow process but at least ongoing. Well I read my books and my undrestanding is I have to loosen the bolts on the pillar not on the door. First I want to know if this is right, second, if this is right how can I do that, I mean how can I access them. To me they are tucke in between the door nad front side panel. Any tip is greatly appreciated.
Nima is offline   Reply With Quote
Old 04-08-2005, 01:45 PM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
If you open the door you can access the front hinge bolts through the opening. You should only have to loosen them, not remove them. I use a floor jack to put light pressure under the front or rear of the door to support it when loosening hinges to align the door. You can adjust the door vertically from the hinge bolts into the body. The bolts into the door allow you to move the front of the door in and out from the body. Remove only one bolt (this will not affect anything) to see how the bracket is slotted then think about it and proceed from there. You might mark around the hinge to know where your initial starting point is as a reference.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-08-2005, 01:49 PM   #3
Nima
Blue 67
Thanks for the tips.
Old 04-08-2005, 01:55 PM   #4
stllookn
stllookn's Avatar
I have also used shims (washers) behind the hinge to get a door exactly where I wanted it.
Old 04-08-2005, 01:55 PM   #5
screamin_c102
screamin_c102's Avatar
Make sure you use some type of padding on the head of that jack.
Like STLLOOKN said, you want to use very light pressure, a floor jack can screw up a door quick.
I used this technique to mount the doors on Screamin' after my help bailed on me, it works well if your careful.
screamin_c102 is offline   Reply With Quote
Old 04-08-2005, 04:57 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
I have to adjust one of my doors also but for the life of me I couldn't figure out how to access a couple of those bolts. I couldn't get a wrench on at least 2 nor could I get an extension in there. Do you use a wobble ended extension or is there some other trick to getting to these bolts. I sure don't want to pull a fender but I just can't see how to do it.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-08-2005, 11:59 PM   #7
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I'm with Jack,I can't seem to get a couple of bolts loose to adjust my door either.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-09-2005, 06:39 AM   #8
Zeke
Active Member
If you look at the picture I don't think it is just adjusting the door. My door looks the same. Bottom real tight front and back and the upper forward almost touching the drip rail, almost like the cab or door is tweaked and not 'square' anymore. On the bottom side it doesn't look like there is any room for adjustment. When I replace the body mounts hopefully it will give me a little more adjustment room. I am not an expert but I would think you would start with the door and get it where you want it top front down the back side and bottom then adjust the fender, cowl and hood.
Like I said I haven't done this but believe you need to ensure the cab and body mounts are in good shape.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 04-09-2005, 07:29 AM   #9
junkyard truck
junkyard truck's Avatar
how to adjust this door
Hi, My truck doors also need adjusting and the problem is getting the hindge bolts loose. I'm going to get a cheap box end wrench from on of those assorted tool tables at auto parts houses and with a torch heat and bend it until it will fit the bolts and allow me to work without damaging the paint (specialized custom tool).
Good luck, Larry
69 chevy short stepside
junkyard truck is offline   Reply With Quote
Old 04-09-2005, 08:26 AM   #10
MOTHERTRUCKERS
We torched a gear wrench just for that purpose.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 04-09-2005, 10:33 AM   #11
Nima
Blue 67
[QUOTE=Zeke]If you look at the picture I don't think it is just adjusting the door. My door looks the same. Bottom real tight front and back and the upper forward almost touching the drip rail, almost like the cab or door is tweaked and not 'square' anymore.
Well, The cab mounts are not new for sure but I think there is enough room on the right upper corner to bring the door down just few mm. Now, I am concerned to touch it since I hear all these problems geting to those bolts. Maybe i just leave alon for now. Thanks though.
Old 04-09-2005, 05:51 PM   #12
Zeke
Active Member
Didn't mean to sound so discouraging just wanted to mention some things that might affect how the door fits. Didn't mention that my door hinges are worn also and with the door open it shifts back but when its closed and supported by the latch it will shift forward and it touches the fender.
Goes back to the old saying 'when I was young I didn't have the money, now I don't have the time' and I am pretty anal when it comes to doing the work myself instead of paying someone. Besides the time I do get to spend on my truck relaxes me. So much so that my wife tells me 'go work on your truck', not often enough though.
1969 C10 350 3spd
Old 04-11-2005, 01:31 AM   #13
Ridgeback
GM/Kent Moore special tool designed to handle hinge bolts.
Kent Moore J-22585 - Front Door Hinge Bolt Wrench. Check any 69-72 Chevrolet Truck Chassis Service Manual.
Ridgeback is offline   Reply With Quote
Old 04-11-2005, 04:47 AM   #14
ZOOMY
door adjust
IMO, the door has to go back about 1/8" & the fender forward about 1/8" to get the gaps correct. The rear of the door has to go down about 1/8" for the door crown & cab crown to match.
ZOOMY is offline   Reply With Quote
Old 04-11-2005, 08:13 AM   #15
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I tried my best to align my door. Got it real, real close. Turned out the hinges were worn out. You can lift the back of my door about 5/16"! Pretty happy with it all things considering. So pick up on the back of your door and make sure it does not give a bunch of slop.
Anyone know of a hinge bushing kit for our trucks?
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 04-11-2005, 10:41 PM   #16
71Shortbed
71Shortbed's Avatar
I got a set of pins and bronze bushings from somewhere. I think it may have been LMC or Brothers. Haven't installed them yet.
71Shortbed is offline   Reply With Quote
Old 04-11-2005, 10:26 PM   #17
shifty
Questionable
shifty's Avatar
When my door decided to eat my girlfriend's arm (it rolled downhill into a pillar w/door wide open), I had to loosen the striker plate on mine to get the door to shut right again. I'm talking about the metal plate above the VIN badge on the driver's side.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-12-2005, 01:58 AM   #18
4x4Poet
Just about every 67-72 Chevy truck parts vendor sells cab/front door hinge pins with bushings. IIRC, they fit 67-87/91 GM trucks, so they're common as all get out.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 04-12-2005, 10:07 AM   #19
chickenwing
I've saw GM truck hinge kits in the Help! section. Box did not list 67-72 trucks so I thought they were differant. Could anyone confirm the year group for the hinge kits please?
Old 04-12-2005, 10:51 AM   #20
Yukon Jack
Post Whore
Yukon Jack's Avatar
I bought a cheap set of kinda S shaped box wrenches last night and it looks like that will get me access to the bolts. Might try to find a better quality wrench of the correct size as the cheap ones I bought are pretty sloppy on the head of the bolt.
