Old 04-08-2005, 02:51 PM   #1
screamin_c102
screamin_c102's Avatar
dropped spindles
I have searched the FAQ and back posts and managed to get completely confused.
I am looking at putting 73-87 3" drop front spindles on my 1971 C10 and I have a few questions.
1. I understand that the lower ball joint is the same on the 71 as the 73-87 is this correct?
2. Will the 73-up upper ball joint fit my 71 control arms?
3. Does anybody offer a conversion tie rod end or sleeve that will allow this setup still, if so who?
4. Will my 71 calipers and rotors work with the 73-87 spindles?
5. have I forgotten anything?
I know that a complete crossmember swap is best and easiest but I already have the spindles and all my '71 parts are new.
screamin_c102 is offline   Reply With Quote
Old 04-08-2005, 03:22 PM   #2
neonlarry
neonlarry's Avatar
#5 yes, don't double post (board rules).
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-08-2005, 03:34 PM   #3
72MARIO
72MARIO's Avatar
CPP sells the adapter so you can use a 67-70 outer tie rod as the inner and the 73-87 as the outer. I think you need 73 up brake calipers rotors etc. (not positive). The 73 upper and lower ball joints fit. You will need to bolt in the uppers.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-08-2005, 03:42 PM   #4
screamin_c102
Sorry 'bout that.
Old 04-08-2005, 03:57 PM   #5
neonlarry
neonlarry's Avatar
I just thought I'd warn you, Josh has been on the rampage lately (http://67-72chevytrucks.com/vboard/s....php3?t=149975). Just curious why you want to go to the trouble of 73-87 spindles vs 67-72 spindles. Modifying the 73-87 steering stop and the cost of the tie rod adaptor sleeve seem more trouble than its worth.
Old 04-08-2005, 04:04 PM   #6
screamin_c102
I'm putting in my bags this summer and I already have a set of 73-87 drop spindles.
Fabrication isn't really a problem, I just wanted to make sure they would swap in relatively easily. Basically gathering info from the board in order to make an educated decision when the time comes.
Speeking of education, I graduated (kinda) from Vaca High. I used to live just out side of Travis on Hay Rd. Went to Elmira elementary and Will C. Wood when it was still a Jr. High. My brother syill lives in Dixon, he's a C5 loadmaster at Travis still.
Small world.
