Old 04-08-2005, 10:57 PM   #1
nu2-72
rear disc plates ?
Anyone ever try using these as rear disc plates? They are from a later model Dana 44 front. Our years have the tin dust shield and "V" shaped backing plate.
These bad boys are 1/4" solid steel all the way around.
Rob, these are the plates I was talking about. Found several of them so I picked up all of them. Think I will play with them and see what I can do.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 04-08-2005, 11:29 PM   #2
drink2mny
drink2mny's Avatar
Mudder i believe uses backing plates with spacers.
I used to on mine till.. You know...The name in my sig, changed me..
Support The Board
drink2mny is offline   Reply With Quote
Old 04-09-2005, 03:33 AM   #3
Mudder
Mudder's Avatar
I have a 14 bolt.
Mudder is offline   Reply With Quote
Old 04-10-2005, 12:09 AM   #4
kwmech
I have spacers for those to adapt to a 14 bolt, but you have to enlarge the center hole and put 4 1/2'' holes in the plate to the 14 bolt pattern
Old 04-10-2005, 12:28 AM   #5
Truckstuff
Truckstuff's Avatar
To use the Dana 44 backing plates on a 14 Bolt for a disc conversion you need an adapter like this one.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 04-10-2005, 11:54 AM   #6
nu2-72
Truckstuff, does that spacer fir the backing plate that I have shown or is it for the plate from our years? Or will it work for both?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 04-10-2005, 12:42 PM   #7
Truckstuff
Truckstuff's Avatar
The backing plates I have are from a 71 - 75 3/4T Dana 44 HD and look like the ones you show. I don't think it matters what style as long as they are 3/4T Dana 44
1985 GM K3500 3+3
1981 GM K2500 SSB
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Old 04-10-2005, 07:42 PM   #8
drink2mny
drink2mny's Avatar
with Truckstuff
Those are what I used to use.
Here is my last set I have.
Support The Board
Old 04-11-2005, 01:47 PM   #9
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
14 bolt rears have lots of options for rear disc, now if you can adapt those for the 12 bolt I would be in line for a set.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 04-11-2005, 03:23 PM   #10
nu2-72
When do you want to start?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 04-11-2005, 06:03 PM   #11
BLAZERMAN
BLAZERMAN's Avatar
I thought you were going to do all the work!!
I think there were 4 or 5 different outer flange's between cars, trucks and different years. I'll see if I can dig up the specs for our year of trucks with the 6 lug rear.
Old 04-11-2005, 10:07 PM   #12
nu2-72
OK then, when do you want me to start?
Do you have a rear out and available?
I can spec it and make something up. With this rain I won't be in the fields for awhile. Got all my greenfields planted just in time. Not so lucky with the other place.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
