1970 K10, 350, 4spd!
Truck won't start!
Last night I got home and tried to start my truck. It acted like it wanted to start but didnt. Then the fuel smell. I assume its flooded and wait a couple of hours and try again. I did this a couple of times last night with no luck. Each time I attempted to start the truck, whether I was stepping on the gas or not I would smell a strong gas smell after it had turned over several times.
This morning I tried to start it without touching the gas peddle. The battery was worn down some so I hooked some jumper cables to it. Let it charge and tried again. Once again the strong gas smell. It turns over strong and gives the little haltering sound like its about to start but doesnt. What should I do to trouble shoot this problem or is there a way to get a flooded truck to start? If the fuel filter was dirty would I get a gas smell but maybe not enough to start the truck or what? |
Professional Grade
How strong is your spark? If you are still running points, it may be time to swap over to HEI. It only takes three things to get an engine to run -- fuel, air and spark. I assume you've got air, and obviously fuel, so that just leaves spark to be bad
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Sounds like you're not getting spark. Did you check if the power lead had fallen off the distributor? Happens to me sometimes.
Brian |
If you've got fuel, it must be fire. You can take off the air breather and pump the gas at the carb to see if fuel is squirting. More than likely it is. If it is, then you're problem is likely in the ignition. Check to see if you're getting spark to the plugs by pulling one and grounding it to the block while someone turns over the engine. You should see (or feel) the spark. If not, it could be the ignition module in your HEI, or points need adjusted if you have a regular distributor. Could be a loose wire at distributor, or at fuse box if HEI.
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
Before you throw any parts at it do the following:
Charge the battery real good. Then get in and push the gas pedal ALL THE WAY TO THE FLOOR AND HOLD IT THERE while you crank the starter. It may just be flooded. If this doesn't work then start looking for broken parts.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
If it got a strong smell of gas without pushing the pedal I would look for a bad float in the carb causing a too rich condition. You can have spark and to much gas and it will just sputter and not fire up. I would also pull the dipstick and smell the oil you could have a fuel pump going bad and leaking. just something else to look at.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
#7 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet ![]()
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
