Old 04-09-2005, 04:26 PM   #1
diggerbob
diggerbob's Avatar
need info on 12 bolt axle shaft for 1970
I just cursed the axle shaft that I had shipped to me from Superior axle. It is about an inch shorter than the shaft I took out. Turns out it is for a 65-69.
All of the axle manufacturers seem to think that 1970 axles have 5 lugs or at least that is what their internet sites say-my '70 has 6. Anyone know the OEM part number for the 1970 12 bolt, series 10 axle shaft? Can I get an aftermarket replacement that uses the original 6 bolt pattern?
diggerbob is offline   Reply With Quote
Old 04-09-2005, 09:47 PM   #2
Rod
Looking at the GM parts book it lists a part # of 1970 rear axle as 3966276 says its the same as 71-72 4wd rear axle..and there 6 bolt ...so might ask for a 71-72 rear 4x4 axle ...and you might get the correct one.
I'll add a little here for the 2wd guys thinking about swap to 71 - 72 axles.
That 70 rear axle is the odd lot...in some cases a 70 rear axle will take a 71-72 5 bolt rear axle...for 2wd applications. It's a swap to 5 bolt pattern that makes this year of diff somewhat sought after as it can be swapped between 5 and 6 bolt axles from stock trucks. I have had a 70 that didn't allow the 5 bolt axle..it was a little longer about 3/4 inch...so I think it might be a change over period where some fit some dont. The typical 71-72 axle is about 3/4 inch longer than the 6 bolt pattern 67- 69 -70ish.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-10-2005, 09:44 AM   #3
diggerbob
diggerbob's Avatar
thank you kindly
I figured that the 4WD axle might do the trick. Hope I can get this thing before the chevy shown next weekend..
