Old 04-09-2005, 09:39 PM   #1
pat
pat's Avatar
What are you all using for radiators?
What kinda radiators are u all using? Mine wasnt in great shape when I got my truck, so Im thinking about putting a diff one in.
What kind are u using, how well does it work, what modifications were necessary to fit it in?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 04-09-2005, 09:59 PM   #2
71Shortbed
71Shortbed's Avatar
I got a nice 4 core with a heater outlet for $133 from Radiator.com. Got it thru ebay. It replaced my 3 core with very few problems. Its a good heavy Modine radiator. I did have to trim the fan shroud just a little for a better fit and switch my mounts for 4 core mounts.
71Shortbed is offline   Reply With Quote
Old 04-09-2005, 10:36 PM   #3
rmrtndl
Hey ya'll, Watch this!
rmrtndl's Avatar
Where did you get the 4 core mounts?
Rick M.
72 GMC SWB Fleetside
25 Chevrolet Superior Series Truck
95 Mazda Miata
06 Dodge Charger RT
http://ram92.ods.org/blog.html
rmrtndl is offline   Reply With Quote
Old 04-10-2005, 12:07 AM   #4
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
i'm using a 30" be cool universal aluminum.
single 1.25" core.
works great!
110-115 degrees F in summer temp climbs to about 190 when the fan comes on drops down to 170 real quick.
only had to fabricate upper rad mounts.
for the money, best to spend the extra dough & get the one made for the truck.
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 04-10-2005, 12:15 AM   #5
Mudder
Mudder's Avatar
All the vendors up there that support us have the mounts. I'm using a four core with a electric fan. No problems.
Mudder is offline   Reply With Quote
Old 04-10-2005, 02:09 AM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I'm using one from a mid 80's V8 Impala station wagon.No mods,or anything,bolted right in,and works like a champ.I'm a member of the run what ya brung club
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-10-2005, 02:43 AM   #7
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Mine still has the factory 4 row in it...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-10-2005, 05:05 AM   #8
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
I have a aluminum one that is actually factory equipment for a 1988 Iroc Camaro with the 350 TPI. It bolted right in and was right at 100 bucks from Napa. Works excellent with my dual electric fans and the temp always runs right where it should. It definetly Works!
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 04-10-2005, 05:40 AM   #9
71-longbed
Its Magically Delicious
71-longbed's Avatar
im running a modine ...
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 04-10-2005, 08:37 AM   #10
NPilot1975
NPilot1975's Avatar
I am running a Be Cool Aluminum Radiator also. It works great, actually too good in the winter. I had to block off all but a 2"x2" square to get heat.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 04-10-2005, 09:56 AM   #11
71Shortbed
71Shortbed's Avatar
I got the new mounts from Tim Christian. He had 3 core and 4 core mounts at the Charlotte Auto Fair.
Old 04-10-2005, 10:01 AM   #12
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
YUP TIM KEEPS THEM IN STOCK, MAYBE A LIL LOW BECAUSE OF THE FAIR,
BUT HE NORMALLY KEEPS THEM IN STOCK - www.christiansclassics.com
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-10-2005, 04:57 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have a 3 core in my blazer and a 4 core in my b.b. c/10 both are stock and work great...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-10-2005, 05:46 PM   #14
junkyardjohn
junkyardjohn's Avatar
I ALWAYS USE FACTORY STYLE (MODINE REPLACEMENT) 4 CORE "DESERT COOLER" RADIATORS. I'VE HAD THEM IN 500 HP. BIG BLOCK TRUCKS WITH NO HEATING OR COOLING PROBLEMS AT ALL. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 04-10-2005, 07:05 PM   #15
ckhd
ckhd's Avatar
I have a Modine 4 core in my 'burb, cools great. The others have stock 33+ year old radiators, and don't cool so good.
I suggest getting a modine. Fit well, works great. I bought a radiator from Checker (shuck's/kragen), and that thing was a pile, it was twisted, and it didn't cool very well.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 04-10-2005, 11:11 PM   #16
SweetandLong68
Your UncleBen
That is what mine is...Modine...Factory equipment for 88 Iroc Camaro
lata
CHRIS
