Old 04-09-2005, 11:56 PM   #1
bluec10
bluec10's Avatar
Dumb Gasket Question
I dropped a new engine into my '76 about a year ago. The other day I was reading an article about carbs in one of the magazines where they pictured the installation. Go figure - they used gaskets and I don't remember using any. I just put that heat spacer on top of the manifold and bolted the carb on top of it. The truck seems to rune fine. Is this a big deal?
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 04-10-2005, 01:50 AM   #2
Russell
Professional Grade
Russell's Avatar
Get both the spacer and the carb a gasket and watch your engine's performance and gas milage increase hugely. You must have an enormous vac leak there...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-10-2005, 07:29 PM   #3
bluec10
bluec10's Avatar
I thought so. Can I use RTV, or do you recommend the original gasket?
Present:
Past:
Old 04-10-2005, 07:46 PM   #4
Jonboy
Slots go on anything!
I would try an original one. You should be able to find them at most part stores.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-10-2005, 10:57 PM   #5
Paso76GMCstepper
Paso76GMCstepper's Avatar
I would get the gaskets they're dirt cheap and your truck "should" run better with them.
Tony
"Life is a Team Sport"
To the memory of the Hendrick Motorsports Plane Crash Victims
Paso76GMCstepper is offline   Reply With Quote
Old 04-11-2005, 01:21 AM   #6
jimfulco
If it's the thick (1/4" or so) gasket, be sure it has hard plastic doughnuts around each bolt hole. These are to keep you from overtightening & warping the carb base. Cheaper gaskets don't have them.
jimfulco is offline   Reply With Quote
Old 04-11-2005, 01:45 AM   #7
badone07
Project 2 Resume
badone07's Avatar
Yes he's right. Also don't use RTV. Permatex #2 or indian head if you have to use anything. But you really shouldn't have to.
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 04-12-2005, 01:39 AM   #8
jimfulco
I always use a coat of Permatex liquid (Super 300 or Aviation) on my carb gasket, even though you don't really need it. It keeps the gasket intact (no peeling) if you have to remove it, & you can usually re-use the gasket. This is handy for unexpected side-of-the-road repairs, or if you're terminally cheap, like me.
Old 04-12-2005, 10:04 AM   #9
bluec10
bluec10's Avatar
This thread reveals my ignorance about carb gaskets. I currently have the thick (1/4") gasket installed. It has the little plastic grommets in the corners. I was wondering if this thing was the gasket, or is it just a heat insulator. From everyone's comments I gather that this thing is the gasket and I don't need to do any additional sealing on the top or bottom of it.
Present:
Past:
