Old 04-10-2005, 12:30 AM   #1
1986Silverado
What I drive
1986Silverado's Avatar
Will a bumper and hitch from a 76 Burb work........
on my 86 C-10? Rear bumper and a hitch that attaches to the frame. Are the frames different?
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 04-10-2005, 12:49 AM   #2
Truckstuff
Truckstuff's Avatar
The Suburban frame is different at the frame end, it sticks out alittle farther and has a flange that the sport bumper mounts too. The PU frame is cut off straight, to make the sport bumper work you need the PU sport bumper brackets.
If the Suburban hitch is a class III style it will bolt to the side of the frame. The PU hitch should bolt to the bottom frame flange.... Hope this makes sense.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 04-10-2005, 01:16 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
when i tried to put a class three hitch on my pickup also from a burb onto an 86 the frame is wider on the burb so it would NOT bolt on
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-10-2005, 04:23 AM   #4
1986Silverado
What I drive
So the only thing I can actually use would be the sport bumper? Thanks
2006 Chevy Equinox
Old 04-10-2005, 09:58 PM   #5
beaterC10
I modified a Burb hitch to build a hidden hitch for my stepside. The biggest difference I saw was that the reciever on the Burb hitch is at a different angle than a pickup. My Burb hitch bolted on, but the reciever was pointed down hill. I cut the cross tube loose from the mounting brackets and welded it back straight.
beaterC10 is offline   Reply With Quote
Old 04-10-2005, 11:46 PM   #6
1986Silverado
What I drive
Guy just emailed me and said hitch was sold and bumper was no good
2006 Chevy Equinox
Old 04-10-2005, 11:56 PM   #7
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Just in case you didn't know, the rear bumber of the '76 is of a different style/profile than those off of a '81+. The '76 rear bumber will not match the lines of your '86 front bumber.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
