Old 04-10-2005, 02:03 AM   #1
pjmoreland
pjmoreland's Avatar
Help! Carburetor is backfiring!
When I rev my engine up slowly, the carburetor starts backfiring repeatedly. It makes a pop-pop-pop-pop noise in rhythm with the RPM of the engine.
It just started doing this today when I was driving down the highway. At first it only happened with the throttle barely open. It got progressively worse over the course of about 10 miles to the point where I thought I wasn't going to make it home.
I thought that maybe a valve had gone bad so I disconnected one spark plug wire at a time to see if there was one cylinder in particular that was causing the problem, but in no cases did the popping go away.
I checked my timing and it is set at 10 degrees. Just as a test I tried retarding the timing to about 2 degrees, but the popping persisted.
The manifold vacuum is around 15 at idle.
I have a mild 350 engine with a four-barrel Quadrajet and an HEI distributor. I triple-checked my spark plug wires. They are definitely arranged in the 18436572 order.
Any ideas?
pjmoreland is offline   Reply With Quote
Old 04-10-2005, 02:11 AM   #2
Alexis
Member since 2000
Alexis's Avatar
check if you have any spark plugs loose.
Alexis is offline   Reply With Quote
Old 04-10-2005, 02:37 AM   #3
pjmoreland
pjmoreland's Avatar
I went outside just now and checked the spark plugs. They were all tight.
Old 04-10-2005, 03:10 AM   #4
pritch
pritch's Avatar
Maybe a piece of carbon or some other junk causing a valve not to close all the way? Maybe check compression.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 04-10-2005, 06:40 AM   #5
JimKshortstep4x4
The way the problem progressed I would suggest pulling the valve covers to make sure the valves are going up and down and that the springs are all good.
Jim
Old 04-10-2005, 08:01 AM   #6
tmcgrawlookalike
Sounds Like A Stuck/burnt Valve
tmcgrawlookalike is offline   Reply With Quote
Old 04-10-2005, 09:47 AM   #7
Mudder
Post Whore
Mudder's Avatar
Compression test time.
Mudder is offline   Reply With Quote
Old 04-10-2005, 10:07 AM   #8
Gordo
Also check inside the distributor cap for carbon tracks, evidence of spark jumping between contacts. I also have seen the wrong screws (to long) installed to hold in the coil and they push/break thru into the cap creating problems.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 04-10-2005, 12:34 PM   #9
pjmoreland
pjmoreland's Avatar
I will do a compression test and will check out the distributor tomorrow. Thank you for the suggestions.
Old 04-10-2005, 04:32 PM   #10
willow72
willow72's Avatar
maybe the timing chain going out
willow72 is offline   Reply With Quote
Old 04-10-2005, 08:23 PM   #11
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Jim
I agree,sounds like a bent pushrod,broken rocker arm,valve or even a lobe off the cam to me.Hopefully it's not real serious.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-10-2005, 09:15 PM   #12
breeh
Recovering 67-72 Addict
breeh's Avatar
I just had the same exact thing happen to my '68. Pulled the valve covers and found that I had lost a cam lobe.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 04-10-2005, 09:20 PM   #13
86SILVERADO
86SILVERADO's Avatar
I would make sure you have no vacuum leaks and the carb is in tune. Also could be a sticky advance in the Dizzy. Those shafts can get so gummed up you can't even twist them by hand.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 04-11-2005, 11:55 PM   #14
pjmoreland
pjmoreland's Avatar
Well I just got done doing a compression test. six of the cylinders measured at around 135 psi. Cylinder 6 measured at 45 psi, and cylinder 8 measured at 70 psi. I popped my valve cover off and watched the rockers as I cranked the engine over. They were moving up and down just fine, and I could spin the pushrods during the compression stroke, so the valves are closing all the way. I'm guessing I have a couple burned valves. Time to pull the heads off. What a bummer!
Old 04-12-2005, 12:20 AM   #15
68cajun
68 C/10
68cajun's Avatar
Are you sure the rockers are moving all the same distance. If you loss a cam lobe it will move but not as much as the others.
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 04-12-2005, 12:33 AM   #16
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I vote for a blown head gasket between 6 and 8. Seems like burnt valves would have a little more compression. Good luck.
VetteVet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-12-2005, 03:20 AM   #17
pjmoreland
pjmoreland's Avatar
Found The Problem
I just got done pulling the head off. The intake valves on cylinders 6 and 8 are split. The head gasket looks like it is in good shape. Any suggestions on what I should do to fix this? Am I asking for trouble if I only replace one head?
Old 04-12-2005, 06:52 AM   #18
OLDCHEV4X4
OLDCHEV4X4's Avatar
those are exaust valves
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 04-12-2005, 09:42 AM   #19
JimKshortstep4x4
Talking
I think that I would have the valves reground/replaced on both heads. You could just replace the two exhaust valves, (regrinding the seats).
One thing that bothers me is that you should not get backfiring through the carburetor with a couple of burned exhaust valves. I still suspect a broken spring or a bad cam.
Did you check the intake valves on the two cylinders?
Jim
Old 04-12-2005, 11:04 AM   #20
VetteVet
Msgt USAF Ret
VetteVet's Avatar
It looks like the area between the exhaust valves where the head gasket was is burned away from the head gasket being blown to start with, which let's me believe that the gasket was blown to start with and it just got worse. The popping through the carb might have been heard when no. 6 intake was open as no. 8 fired and vice versa. I can't remember the valve timing so that may not be the case. I've got an old cam that I will look at later out of curiosity. Iwould make sure the head wasn't warped also. It might be quicker and easier to just slap another good head on and go. Just my thoughts
VetteVet
Old 04-12-2005, 11:11 AM   #21
pjmoreland
pjmoreland's Avatar
Is there a quick way to check the cam without removing it?
Old 04-12-2005, 11:19 AM   #22
pjmoreland
pjmoreland's Avatar
So do you think it is ok just to replace one head? I just worry about the compression being uneven between the two heads.
Old 04-12-2005, 11:21 AM   #23
pjmoreland
pjmoreland's Avatar
VetteVet, I'll bet you're right about the blown head gasket.
Old 04-12-2005, 12:31 PM   #24
midyearvet@aol.
Probably a flat exhaust lobe on cam. Exhaust is poping back up through carb.
midyearvet@aol. is offline   Reply With Quote
Old 04-12-2005, 12:50 PM   #25
JimKshortstep4x4
Talking
The area of the head in the picture between the two cylinders does not appear to be an indication of a blown head gasket. Besides that, the area shown is between cylinders 4 and 6 and no 4 cylinder had 135 psi compression according to the compression test.
I am still concerned about the popping through the carburetor, though.
Jim
