04-10-2005, 01:37 PM | #1 |
700r4/np208 question
My '85 Blazer started leaking ATF real bad last week...it looks like its coming from the transfer case...is the ATF in the T/C cycle from the transmission or do you have to fill it separate?
It looks like its coming from the gaskets but i'm not real sure... Thanks, -Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
04-10-2005, 03:50 PM | #2 |
208's use ATF not gear oil I believe and they do have separate fillers. The T-case has two big nuts on the back side the bottom one is the drain and the top is the fill hole.
04-10-2005, 05:14 PM | #3 |
ok, thanks, I'll check the level tommorow hopefully
04-10-2005, 07:38 PM | #4 |
It is a possabillity that your seal between the t-case and tranny might be bad.
If that happens you usually get a lot of fluid pissing out vent tubes and the rear driveshaft seal. I mean the input seal not the gasket seal between the 2. they go bad.
Support The Board |
04-10-2005, 08:20 PM | #5 |
yeah, it looked like it was coming from b/w the tranny and t/c...do you know where they sell the seal? is it still a dealer item? I couldnt find it at Autozone, advance, or napa
