Sway Bar Install
I couldnt get any moog bushings for the 1 1/16 sway bar but I got some energy and they come with brackets. The brackets that came with the bushings cover the entire bushing. The GM ones only cover 2/3rd of the bushing. Should I use the energy ones or the GM ones?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
I would use the brackets that came with the bushings, the bushing and bracket are probably designed for each other.
Post some pics when your done if possible. ![]() |
Here is a pic of the bushings. Ill post pics of the install when I do it.
Forgot to say that the top is GM and the bottom is the one that came with the bushings.
I used the Energy ones on mine.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I would use the energy ones with the energy bushing's...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I looked at the the brackets back to back and they line up almost perfect. I will use the energy one. Besides they are purdy!!!
