Old 06-09-2002, 03:40 PM   #1
bigdog67gmc
hei wiring please help
putting hei out of a 86 blazer. I know u run a hot wire from the battery side to the fuse box but what about the four pin plug. do u have to connect any of them to anything . thanks
Big Dog 67 GMC, 4x4, 4" lift, 35 groundhawgs, under construction, Fresno, CA
bigdog67gmc is offline   Reply With Quote
Old 06-09-2002, 04:34 PM   #2
Blue_71
Bloo
Blue_71's Avatar
four pin plug wired to bottem of distibutor? you know where the battery terminal is on the cap, well that plugs in behind that, close to the cap
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 06-09-2002, 05:23 PM   #3
bigdog67gmc
blue 71 the wires your talking about ? i have no place to plug them on my 67 gmc . well this set up work for me? thanks for all your help
Old 06-09-2002, 05:50 PM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
The 86 distributer you are trying to use was made to work with a computer, you need to find a distributer out of an 75 to 82 chevy v-8 with vaccume advance.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 06-09-2002, 06:21 PM   #5
Zkast
Zkast's Avatar
If you absolutly have to use that distributor you can connect the black and brown wire together, This will bypass the EST(Electronic Spark Timing) circuit and allow you to time it as usual.
Or you can replace the ignition module with a standard 4 pin and just remove the old 4 wire harness from the housing (put silicon in its place though)
Zkast is offline   Reply With Quote
Old 06-09-2002, 06:29 PM   #6
bigdog67gmc
thanks everyone for your help!
Old 06-09-2002, 10:12 PM   #7
Blue_71
Bloo
Blue_71's Avatar
didnt know about the computer thing, ive never seen one from a vehicle with a computer
1989 Chevy K2500
