Old 04-10-2005, 10:26 PM   #1
55stepside
73-77 IFS swap
I have a 77 half ton chevy frame and running gear. Would it be a farily simple install to put the IFS of that frame onto my 55? I think I heard somewhere that it was almost a bolt in set up but I am not sure.
55stepside is offline   Reply With Quote
Old 04-11-2005, 02:57 PM   #2
Norselander
Clunker Farm, Proprietor
Norselander's Avatar
It might be just as easy to swap to the '77 frame. I have a short '73 under my '58 body. The cab mounts line-up (requires a spacer) but you have to move the rear spring hangers forward to line-up the rear axle with the fender openings.
Have a look...
It's sitting kinda tall out front but it'll drop right down with a motor and tranny in place. I've actually been thinkin' of putting that body BACK on a '58 31 frame.
Drew
Chief Junk Jockey
Norselander is offline   Reply With Quote
Old 04-11-2005, 09:51 PM   #3
55stepside
Thanks for your help.
Old 04-14-2005, 10:54 AM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Its almost a bolt in for a 55 1st. But it takes narrowing the front frame rails to get it into a 55 2nd -59. I did it in my 58 and its a lot of work. But you do end up with a truck front end in your truck.
dwcsr is offline   Reply With Quote
