04-10-2005, 11:15 PM | #1 |
Active Member
Temp sensor problem
Does it make any difference where the temp sensor is located? Moved mine from head to intake when I changed heads. Had it fired for the first time today and the temp guage needle goes all the way to the left the the engine geets warmed up. Engine doesn't seem too hot and the antifreeze isn't steaming and boiling out.
69 C10 LWB Project 47 Cushman Scooter Project It is better to have loved and lost than to live with a psycho all your life. |
04-10-2005, 11:29 PM | #2 |
Designated Grumpy Old Man
Did you use your old sender or install a new one? If it is a new one odds are the parts store gave you one for the idiot lights not the gauge style.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
04-10-2005, 11:40 PM | #3 |
Active Member
It's the old sender. That's why I'm confused.
04-10-2005, 11:50 PM | #4 |
Hmm! Let me think on that. How is the ground? With it running run a wire to the battery - post to the base of the sender and see if it makes any differance if not then check the wire going to the sender it may have a few broken wires in it and is putting up too much resistance. Other than that I don't have a clue.
04-11-2005, 07:34 PM | #5 |
Active Member
Thanks for the suggestions. I'll give them a try.
04-11-2005, 10:54 PM | #6 |
If it is a stock gauge shouldn't it go all the way to the right ? Did it work before? Did you use teflon tape on threads? If you did it will not be grounded so the gauge should read all the way to the left as you said.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
