Old 04-11-2005, 10:17 AM   #1
Putter
More Cowbell....
Putter's Avatar
My 250 gained some weight!!!
Well, I am finally getting around to posting pics of my old truck's new power plant. I yanked the inline out of there (which is for sale - by the way) and dropped a small block in it's place (thanks to one of CHEVYE's hella-deals, and a ton of board-member parts). So after several hours with G-Man69 and some horse-trading for parts, here is the result.
Before & after...oooooohhhhhh....aaahhhhhhhhhh
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-11-2005, 10:25 AM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
man that looks really good in there !!!!!!!!!! i like it and i see ya added power brakes too !!!!!! bet that helps out too!!!!!!!! wish mine looked that good
tnblazerk5 is offline   Reply With Quote
Old 04-11-2005, 10:26 AM   #3
tnblazerk5
User #12137
tnblazerk5's Avatar
hey how did ya hook the power steering pump up to the box ? isnt the fittings differant ?
Old 04-11-2005, 10:28 AM   #4
timmosams
Looks great
What do you want for the 250? How many miles does it have? How does it run? Any and all info would be appreciated.
timmosams is offline   Reply With Quote
Old 04-11-2005, 10:33 AM   #5
68cajun
68 C/10
68cajun's Avatar
Where did you get the Idler to replace the A/C compressor on the 1 belt setup? I have a setup and need the that part to install it without the ac. Oh yeah the engine looks great!
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 04-11-2005, 10:48 AM   #6
Putter
More Cowbell....
Putter's Avatar
I will start from the top and work down...
NOTHING was power from the factory on this one. I have added power brakes and power steering. The power steering pump was a metric fitting and the box is a standard. I took the correct hose for each, then cut and spliced as close to the pump as possible. Lucky for me that BOTH lines use 3/8" metal tubing, which made it easy to splice.
The inline 250 is not the original. It is out of a 1968. I got it from board member Bowtie468. It runs great, but the throw-out bearing in the tranny is shot (one reason to swap engines now!) I does have a leak in the area of the timing cover. Not sure if the cover gasket is leaking or the one in the center of the cover. Didn't check because I was puilling it out anyway. I would take $50 for it and leave the 3-speed connected to it or trade for something I need!!
I got the A/C delete pulley from board member WES. He sells them new and they are GM parts. I gave in the neighborhood of $55 I think.
Old 04-11-2005, 11:43 AM   #7
TRUCKGUY
TRUCKGUY's Avatar
looks great
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
Old 04-11-2005, 12:00 PM   #8
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Please post some more info on the belt system....also how did you wire up the alternator???? Is that a newer block w vortec heads or an older block with the regular heads. Will that pulley system bolt up to any short block????
IT WOULD BE GREAT IF YOU COULD PUT UP A FAQ SHEET ON THIS STUFF!!!!
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 04-11-2005, 02:14 PM   #9
Russell
Professional Grade
Russell's Avatar
Those are standard chevy heads. The Vortec heads have center bolt valve covers. And yes, the serp setup will bolt up to most any small block that have accessory holes in them.
Ask NeonLarry about wiring up the alternator. You need to put an inline resistor into the circuit for some reason that I cannot remember.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-11-2005, 03:42 PM   #10
Putter
More Cowbell....
Putter's Avatar
That is half correct. You have to install a resistor inline with the brown wire only IF you are not going to use a warning light. You can run both a warning light and a gauge if you want. That is what I am doing. The bulb gives just the right amount of resistance to keep the internals of the new regulator from burning up. The bulb is also handy to have because if you sling a belt, it will light up instantly to let you know. The voltage needle won't let you know until the battery starts to drain down.
To use the new model CS-130 alternator, or CS-139d, you completely do away with the external regulator. Remove the blue wire and the white wire completely. There is a splice where the red wire from old regulator connected to the red wire that leaves the battery and goes from the passenger side to the driver's side. Those splice in with a red wire that heads towards the firewall/bulk-head. My splice was hidden in the black tape-wrapping up-stream a few inches from the old regulator. You can cut out the regulator part, so the the wire goes from the battery, straight towards the fuse block. Now, the only wire left should be brown. It will connect to the "L" terminal of your alternator (that stands for lamp). You might have to extend the wire for this...mine was too short. If you are not going to run a light, you will have to install the resistor (I can get the correct size later if needed). If you are running a lamp, you are almost done.
So, you either have a lamp, or a resistor....great! Just one more wire to cut. Under the dash, at the ignition switch, there are two brown wires. One solid brown, about an 18 gauge...LEAVE IT ALONE. There is also a brown wire with a white stripe, roughly 20 or 22 gauge. Cut it and cap the two ends.
That is all there is to it.
Hope that helps.
Old 04-11-2005, 03:44 PM   #11
GMan69
GMan69's Avatar
How 'bout some pics of your new instrument cluster? Y'all, his new cluster ROCKS!!! Once again, congrats on a job very well done.
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
Old 04-11-2005, 03:46 PM   #12
Putter
More Cowbell....
Putter's Avatar
Look on the FAQ board George. Also, look at the thread that asks "What size gauges are you running?"
