Old 04-11-2005, 01:46 PM   #1
decade22ten
decade22ten's Avatar
rear sway bar install
does anyone have pictures or install instructions on a 67-72 rear sway bar? any help is appreciated.
decade22ten is offline   Reply With Quote
Old 04-11-2005, 03:46 PM   #2
smokekiki
Mike
smokekiki's Avatar
Here is one about using a camaro bar http://www.low69cst.freeservers.com/CamaroBar.htm
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 04-11-2005, 03:52 PM   #3
Joe67
67 is sold
How sturdy is that setup?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 04-11-2005, 04:27 PM   #4
neonlarry
neonlarry's Avatar
Thats the way the factory hooked them up on a Camero. So I guess its sturdy enough, works fine on my truck.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-11-2005, 05:31 PM   #5
smokekiki
Mike
smokekiki's Avatar
I can't see were it would be less sturdy than the stock front.There are a lot of cars and trucks that run swaybars with end links.
Old 04-12-2005, 12:27 PM   #6
decade22ten
thanks
I wanted to thank you guys for the pics and info. Looks like a stout setup with the camaro swaybar. thanks again.
Old 04-12-2005, 12:45 PM   #7
chevybill
chevybill's Avatar
www.classicperform.com has instructions for installing a rear bar on a coil spring truck and you can print it if you need a paper copy.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 04-12-2005, 01:28 PM   #8
decade22ten
thanks
hi. thanks chevybill.
Old 04-12-2005, 06:47 PM   #9
see ten
WTB this ad
see ten's Avatar
Wouldn't the Camaro bar be a little tight on a truck with a 6" drop? ECE said with a 6" drop I would have 3" between the frame and the axle tube. If I were to use a Camaro bar would I have to run a C notch for extra clearance? The CPP bar that goes on the bottom of the trailing arms looks like it would eliminate this issue.
see ten is offline   Reply With Quote
Old 04-13-2005, 08:13 AM   #10
smokekiki
Mike
smokekiki's Avatar
I have been told that the ece style bar doesn't work very well.No personal experence.There was a pic of a lowered truck with the camaro bar a while back.
Old 04-13-2005, 08:35 AM   #11
smokekiki
Mike
smokekiki's Avatar
Here is a thread that shows the camaro bar.It does look like You would need a c-notch.http://67-72chevytrucks.com/vboard/s...ht=camaro+sway Here is a link to a pic of ccp's bar.I don't care for how low it appears to hang.http://www.classicperform.com/CP7401.html
Old 04-13-2005, 03:30 PM   #12
neonlarry
neonlarry's Avatar
^ In that thread the pics of mine are with 4" drop coils plenty of clearance there.
