Old 04-11-2005, 05:38 PM   #1
fire235
power steering conversion
Does anybody company/person sell a complete kit (every thing needed including pitman arms, link, brackets, etc) to convert a 68 1/2 ton to power steering. I would like to buy a complete setup so I don't have to try to chase down misc. individual parts. Thanks.
fire235 is offline   Reply With Quote
Old 04-11-2005, 10:15 PM   #2
shifty
Questionable
shifty's Avatar
I've seen several for sale on the forum from other forumgoers. I have one of them on the way as we speak (hope for it to arrive this week) and there were two available. I'll let you know how it goes.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-11-2005, 10:19 PM   #3
Randy70C-10
Randy70C-10's Avatar
Still waiting for a reply from a member, but I can put you next in line if you're interested.... http://67-72chevytrucks.com/vboard/s....php3?t=150571
Randy70C-10 is offline   Reply With Quote
Old 04-11-2005, 11:34 PM   #4
0ptikal
what is a link bracket? I just changed the power steering arm / pitman arm and put a pump on.... maybee i forgot something... doh
0ptikal is offline   Reply With Quote
Old 04-12-2005, 01:15 AM   #5
4x4Poet
Consider a power steering conversion kit from Rez Engineering up in Great Falls, MT. Rez sells complete pwr steering kits. I just found out about Rez in January. He dabbles in all Chevys, but has an inventory and catalog that specializes in 60-72 Chevy & GMC trucks.
I came to find out he designed the original power steering conversion kits that several companies now copy cat. Several 60-72 vendors sell his power steering conversion brackets. I found proof. The article below speaks to Rez's 60-66 conversion.
Custom Classic Trucks Article
But for your 68 1/2 ton 2wd?, no need for gearbox brackets. The power steering gear Rez supplies bolts right to your frame. From Rez Engineering's catalog:
1. Steering gear, variable 3.5-3.75 turns lock to lock.
2. Pitman arm.
3. Rag collar (New rag installed in joint with correct splines)
4. Hardware (all new bolts, nuts, washers, cotter pins, etc).
5. Correct style pump (mounts down low on drivers side with V8)
6. Correct hoses (flared ends).
7. You use your 2wd drag link.
Give him a call, M-F, 8-5 MST, @406-727-9267. He's very informative. I'm not an employee, though when I make the trip to his locale, I do get a small walk in discount that all walk-in Montana "locals" get. While I would recommend Rez to anyone, I recommend Rez to you because Power Steering Conversions for Chevy/GMC trucks is his specialty. Good hunting.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 04-12-2005, 01:40 AM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Interesting article, I didn't realize the boxes were different lengths and you would have to shorten the steering arm. Didn't seem like much of a hassle though.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-12-2005, 12:49 PM   #7
fire235
Just ordered a kit from rez engineering. He sold the complete kit at a resonable price that includes everything needed. Thanks for the info.
Old 04-12-2005, 12:54 PM   #8
timmosams
just out of curosity how much was it, for the complete kit?
timmosams is offline   Reply With Quote
Old 04-12-2005, 01:29 PM   #9
fire235
The kit for the 68 was 485.00, and includes everything to bolt right in.
Old 04-12-2005, 05:32 PM   #10
timmosams
O.K. thanks.
