headlights stopped working
my headlights just quit working, no warning. i changed the switch, dimmer switch, horn relay. i checked all the fuseable links i could find and they are ok. all fuses are good also. any help will be appreciated. thanks
my taillights did the same....turns out it was a bad ground
Until Seventy Times Seven
Sounds like it could be a bad ground or a loose connection.
Here's a few things to try: Check the connections at the headlights. - Check the ground terminal (black wire) with an VOM meter for a good ground. - Check the other terminal(s) for voltage with a VOM (with the headlight switch in the ON position). - Check for a solid connection between the headlights and its' connectors. - Check for good headlights. Check the terminals at the lightswitch. - Check the red wire terminal with a VOM (or test light). If no voltage, repair open red wire to battery (fusible link). - Check the yellow wire terminal with a VOM (or test light). If no voltage, replace light switch. - Check the yellow wire terminal at the dimmer switch with a VOM (or test light). If no voltage, repair open yellow wire. - Check the other terminals at the dimmer switch with a VOM (or test light). If no voltage replace dimmer switch. Check the circuit between the dimmer switch and the headlights. Good Luck
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
Chevys Kick A$$
Yeah sounds like a bad ground somewhere.
-BoxRodz list most of the places to check. -Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
BeWarE tHe eViL CrAnkTOe!
Mine did just this and its a bad hi/lo switch in the column...that is if your switch is on the column. Fixed mine....then the bastage thieves busted my column.
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
I checked all the grounds i could find and i still have no power to the switch
If you have no voltage to the 'hot' side of the switch, then it sounds like you have an 'open' between the switch and battery. I know you check the fusible links, but it sounds like maybe the fusible link is bad.
I gave up and took it to the garage. Thanks everyone for the help.
pappyracing-
Did the shop get your headlight problem resolved? Just curious what the problem was?
