2'' Suspension lift
I was wondering what the best 2'' suspension lift would be and if it would be ok using rear blocks. I'm not a real big fan of blocks but i figure just going 2'' isn't too much and i shouldn't have much axle wrap if any...
Mike
What truck,2wd or 4x4?I like tuff country lifts.If you are running a block,2" is not that bad.You could also run an add-a-leaf.Once You get new front springs,You might find that the rear springs are sagging and will need replaced or more than 2".
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
