Old 04-11-2005, 08:31 PM   #1
silvertonguedevil
silvertonguedevil's Avatar
Will a 67-72 cab fit in the bed of a 71 Chevy long wide box??
Just what it says. I will be needing to take my cab across town and I just wanted to see if anyone had done this.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 04-11-2005, 08:37 PM   #2
Huck
Huck's Avatar
Fits fine but sideways with the wheel tub fitting in the middle of the firewall.
Huck is offline   Reply With Quote
Old 04-11-2005, 08:49 PM   #3
ronh72c10
Yup, it is a little tight though.
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 04-11-2005, 08:53 PM   #4
silvertonguedevil
I'm not all that concerned with the '71 that I'll be hauling it in....but I don't want to do any damage to the cab that'll be in the back. Will that be ok?
-Greg
1974 C20 Cheyenne
Old 04-11-2005, 08:55 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You can do it in a short wheel base too, but the tail gate will put a small dimple in the upper cab corner.
Old 04-11-2005, 09:29 PM   #6
Longhorn Man
if you put some padding around the cab where it'll hit the bed, and go easy when dropping it in there, and drive around the potholes, you should be OK...but some small damage will be hard to avoid.
