Old 04-11-2005, 09:19 PM   #1
Joey-D
City's Articulation Ramp
Joey-D's Avatar
Rear Flip Kit Towing and Ride Quality?
I just bought a 99 Silverado 2wd 4.8 standard cab SWB. I have been looking at drops. First I wanted the 3/4, but after realizing I could do a 4/6 for cheaper, I got thinking about it. The only thing holding me back is how does a flip kit do towing. I have a tandem axle car hauler and plan on towing that behind the truck on ocasion. I will be adding some airbags on back for extra support, but how does things change when put the axle over the spring. I figured I could buy new spring perches for $13, weld then on the bottom of the spring, and make my own c-notch. Minus shocks, add ubolts and I have $25 in a rear drop, then coils and spindles or a-arms up front. Any opinions on this would be greatly appreciated.
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
Old 04-12-2005, 09:43 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Go with the DJM 4/6 drop. Very reasonably priced. Check around for prices,... But I think Stylin Concepts has a good price. You can search over at www.fullsizechevy.com or www.gmfullsize.com. That's the choice for a cheap static drop. I had one on my old '99 scsb. Skip the "toxic" brand shocks and use Doesche Techs from Summit Racing.
Keith
Convert to disc brakes.
Old 04-14-2005, 12:49 AM   #3
Joey-D
Joey-D's Avatar
I have hurt bad things about DJM, and also I would much rather do my drop myself, the cheap way. A belltech flip kit is 310.00 at truckperformance.com. Like I said, spring purches for 13, u bolts if neede for 10, and then a c notch. I could make my own or order one for 100.00. The best idea I heard for a c-notch was to cut a 3 1/2 or 4" metal pipe in have and cut the frame and weld that in and box it. But I think that would look cool, but we all know a right angle triangle is the strongest shape. So a tradional c- notch might be what I make
Old 04-14-2005, 08:49 AM   #4
74Pumpkin
Insert witty comment here
74Pumpkin's Avatar
At Sport truck Direct there is a flip kit with the C Sections for $149.00 that comes with everything. If your intrested.
http://www.sporttruckdirect.com/rear_kits.html#flipkits
So many trucks, So little time!
74Pumpkin is offline   Reply With Quote
Old 04-14-2005, 03:48 PM   #5
XXL
Señor Member
XXL's Avatar
Just purchased a DJM 4/6 kit from Stylinconcepts (thanks to slammed67 for the install ). The kit appears well made-- heavy steel, parts powdercoated, etc. The kit was missing some of the hardware and the instructions are lame (but you probably don't need instructions for a flip kit... it's pretty straightforward).
DJM _thinks_ that their kit is a bolt-on for a Tahoe, but there are several Tahoe-only hurdles to deal with. I called their "Tech" line and was thoroughly unimpressed... all they were willing to do was essentially read the docs. When I pressed them for technical discussion, they fell back on the "we can't discuss that due to legal liability." WTF???
As for Stylinconcepts as the vendor... meh. Very pushy, not very customer-focused (I was a "customer number," press 1, press 2, and so on).
XXL is offline   Reply With Quote
Old 04-14-2005, 06:37 PM   #6
Joey-D
Joey-D's Avatar
I like stylinconcepts for there catalogs, to see whats new. There prices though seem to be through the roof. Looking at that link right now, there prices are great. I am a guy who would work 10 hours to save 10 bucks, but with these prices, I might just order a kit. Anyone used there stuff before?
