Old 04-11-2005, 09:54 PM   #1
DBLSPRT68
DBLSPRT68's Avatar
Help with pulse wipers
Hello all, I've been working on my truck the past few weeks to get ready for the trip I just got back from (8hrs down empty with trailer- 10hrs back loaded to the gills and a 65 bel air!). Last week I checked my wipers and all worked well. I turned on my wipers the other day and only have high speed! I have an 83 with pulse type switch mounted on the dash. Any ideas? Why is it working in high speed only?? Hope someone can help. David
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 04-11-2005, 10:43 PM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Good question
Mine do(es) the same thing. Only not all of the time. I've pryed the switch apart & cleaned up all of the surfaces. No change. The I pulled it apart again and carefully lubed it with copper grease. Okay, it's better but still a little funny. Try cleaning it up, it may improve it, but if my epxerience is typical, you'll end up getting a new one eventually. I'm hoping someone tells me I'm wrong & posts a solution. Good luck w/ the switch but more importantly, good luck with the bel air.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 04-13-2005, 08:57 PM   #3
86-C10-V6
Shadetree Mechanic
86-C10-V6's Avatar
Most likely the Pulse controller under the dash
I am not familiar with the 83 but the 86 model has a wiper module located under the dash, attached to the steering column.
I think the high speed wiper switch setting, bypasses the pulse controller.
My controller had broken solder joints on the main transistor that is used to pulse the wiper motor, touched it up with a soldering iron and no more problems.
Good luck.
Dave M. (Hacksaw)
86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance
89 GMC S-15 Extended Cab 4x4, 4.3L, FI
98 K1500 Xcab, 5.7L, 3.43 Gov-Lok
86-C10-V6 is offline   Reply With Quote
Old 04-14-2005, 02:35 AM   #4
DBLSPRT68
DBLSPRT68's Avatar
Thanks for the info Hacksaw. My switch is on the dash, but more likely is the same principle. I'll have to check into cleaning the switch or getting a new one. I was also thinking that high speed bypassed everything, so that sounds like the pulse/intermit part of my switch is bad. I'll post later if I find out what it is. David
Old 04-14-2005, 04:02 AM   #5
Esteban86K5
Esteban86K5's Avatar
I think hacksaw may be talking about this.
If so, I just ripped it out of my truck and you can have it for $10 plus shipping if you want.
Be American Buy American
My Pics
Esteban86K5 is offline   Reply With Quote
Old 04-15-2005, 01:42 PM   #6
85gmcguy
Plays with trucks
85gmcguy's Avatar
Smile
Not to hijack anybody's thread or anything, but you guys might have accidentally answered my question.... I installed a tilt column from a truck with cruise and intermittent wipers into my 85 GMC which didn't come with those options. Everything works OK except the wipers, they only work on low no matter where the switch is, I'm guessing now that I may need one of those modules. Well, off to the junk yard
Gary
85gmcguy is offline   Reply With Quote
Old 04-18-2005, 07:17 PM   #7
DBLSPRT68
DBLSPRT68's Avatar
Hey Esteban86k5 is that from an 83? Do you know if it will work in my 83? I haven't had time to look, but give me a day or two so I can look. Thanks, David
Old 04-18-2005, 09:22 PM   #8
bagged74
its just $$$$$
bagged74's Avatar
I believe if the switch is on the dash, the module is a little different.
bagged74 is offline   Reply With Quote
Old 04-18-2005, 09:55 PM   #9
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
That box isn't the pulse wiper module. The wiper module has an aluminum heatsink on one side and looks like this:
I think the box above is for cruise control.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 04-18-2005, 11:06 PM   #10
Esteban86K5
El Gracho is correct. The box I posted above is for CC. I have the other one for the wipers too if you want it. I'll get a pic of it for you.
My Pics
