Old 04-11-2005, 10:01 PM   #1
1978steven
1978steven's Avatar
Three Speed to TH-350
I'm converting my 1971 Chevy LWB from three speed column shift to a TH-350 automatic. I have everything to do the swap, but I'm tring to find out if I will have to change out the three speed tranny yoke for the TH-350 tranny yoke?
Thanks,
Steven
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 04-11-2005, 10:07 PM   #2
RicksTrucks
RicksTrucks's Avatar
I believe you do need an auto cross member
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 04-11-2005, 11:38 PM   #3
69 longhorn
the slipyolk should be the same (3 spd saginaw to 350T). if you are using the 6" tail 350T, the shaft will also be the proper lenght. Yes, as already mentioned, you will need an auto trans crossmember.....& will probably need to cut the old bell mount crossmember out. its not too bad a swap, best of luck.....crazyL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-12-2005, 07:44 AM   #4
1978steven
1978steven's Avatar
I have the short tail th350 (I believe), auto cross member, auto column, all the linkage for the column, and flex plate. Still need to get the starter, radiator, and hard tranny lines.
So if I'm tracking you guys, the short tail I have will need a little bit longer drive shaft?
2004 Tahoe LT
1971 Chevy C10
Old 04-12-2005, 08:26 AM   #5
JimKshortstep4x4
Talking
As 69 longhorn mentioned the drive shaft will be the right length to use as is
as long as you have the short tail 350.
Jim
Old 04-12-2005, 09:21 AM   #6
tnblazerk5
User #12137
tnblazerk5's Avatar
dont forget to take the pilot bushing out of the end of the crank !!!
tnblazerk5 is offline   Reply With Quote
Old 04-12-2005, 08:51 PM   #7
1978steven
1978steven's Avatar
I got it now!!!!
I was thinking the 6 inch tail shaft was the long tail........
I think I got it all... Thanks for the help everyone. I'l let you all know how it goes.
Steven
2004 Tahoe LT
1971 Chevy C10
Old 04-13-2005, 01:57 AM   #8
Johnny05
Johnny05's Avatar
Don't forget the Torque converter..
Johnny05 is offline   Reply With Quote
Old 04-13-2005, 07:35 AM   #9
1978steven
1978steven's Avatar
yup, got that too.......
2004 Tahoe LT
1971 Chevy C10
