Old 04-11-2005, 10:11 PM   #1
jfrank133
AUSTIN TX
jfrank133's Avatar
Question Truck is Need Help with Truck that has barely power.
About a month ago i replaced the head gaskets on my 87 chevy scottsdale, it has a 305 with fuel injection. Ever since i replaced it, my truck has no power it runs but like its barely making it, whenever i come to a stop at a light or stop sign and i give it gas to go it like wants to die. The timing is good, i checked it, double checked it and its good, also changed that EGR valve, and several emission sensors with no luck. Now i was told that it can be that i over tightend the heads, or can it be something else that i missed. I just dont know what else to check. Please help.
jfrank133 is offline   Reply With Quote
Old 04-11-2005, 11:56 PM   #2
badone07
Project 2 Resume
badone07's Avatar
Doubt you over tightened the heads if you torqued them to spec. Valves adjusted properly, check for any vacuum leaks? Other than a cr drop, did you use 305 head gaskets?
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 04-12-2005, 07:45 AM   #3
jfrank133
AUSTIN TX
jfrank133's Avatar
yes, I did use a 305 head gasket.
Old 04-13-2005, 02:17 AM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I would also say check for vaccum leaks. Don't think you tighten the heads too much if they were set up to specs.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
