68 C/10
Smog pump delete
Anyone know where i can get a smog pump delete for a serpentine belt setup out of a 1991 suburban? It would be a bracket and idler pulley looking thing.
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
Have ya tried looking at a S10 4.3 serp setup? My 90 Jimmy with a 4.3 doesn't have a smog pump. It has an idler pulley that just bolts right to the alternator/smogpump bracket.
If your bracket has the hole all you should need would be the shouldered bolt and the pulley, (and probably a shorter belt).
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
68 C/10
I'll look into it thanks for the reply.
Just take your junk air pump off,toss it away..worthless weight riding around
And go to the part store,get the idler pulley,it will simply bolt to the bracket you allready have. and a new belt of corse...I just did the same thing to a 90... Easy to do...
| Bookmarks |
