Old 04-12-2005, 01:18 PM   #1
myet2002
4x2 to 4x4
Does anyone know if the frame rails on a 78 2wheel drive are the same as on a 4wheel truck? I have a 78 gmc c-1500 daily driver and a 75 k-1500 chassis with a bent frame. Can the 4 wheel spring hangers and cross members be bolted to the 2 wheel frame with minimal mods?
myet2002 is offline   Reply With Quote
Old 04-12-2005, 02:43 PM   #2
Russell
Professional Grade
Russell's Avatar
Yep, the two frames are the same part number infact!
Just make sure that you measure like 8 times, drill once, and drill straight! You don't want any misalignment in your front suspension
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-13-2005, 09:22 AM   #3
myet2002
Thanks for the verification there! I thought just by looking that framerails were the same. I think if I begin by basing the front mounts for the front springs off of the core support mount holes that should be a decent place to start. If anyone out there has done this before any infor would be much appreciated!
