good size wheel and tire for 4x4?
i want to go with 15x10 but my dad thinks 15x8, not sure whats your opinion. It sits stock and has really skinny 16 inchers on it now. i want to go with "Ultra 50/51 series" wheels and "bridgestone dualer" tires...
thanks
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
Strongman Garage
![]() Join Date: Apr 2000
depends on what size tire, if your going with a 10.5 or 11 inch tire id stay with 15x8, any bigger and id go 15x10 make sure the tire is ATLEAST 31" tall
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
#3 | |
Bloo
im going with 16x10 with 33/12.5/16 when i get th emoney
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
here's what my 33" look like mounted to factory rallies(15"x8")
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
user # 2756
![]() Join Date: Jun 2001
I have 325/60R15s on 15"x10" rims, no lift. The tires catch the front of the wheel well every now and then. They don't stick out in the back, but they stick out in the front by about 2". Just means I have to wash the truck more often.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
I have 35x12.5x16.5 on my 71 with a 6" lift.
I think they might be just a little too big. when these wear out I'll probably get something just a little smaller not quite as tall. My wife has trouble getting in the truck. |
Strongman Garage
4x4s are a good 2" wider in the front than back from the factory
SKINNY TIRES RULE!
I'm also running 35"s but mine are 35x12.5x15 with a 6" lift. I think it is a nice size, not too tall. My first k-5 had a 4" lift with 35's. It is hard to tell the difference between the two.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
what if i put a 15x8 on the front for the 2 inch deal and 15x10 on the back.. how would that look? with say, 32's?
![]() Join Date: Jan 2002
Keep the same wheel size front and back on a 4X4 otherwise it will drive terrible in four wheel drive and you risk breaking something in the driveline. Even the rim width should be the same size because the circumferance of the same size tire will be different if you put them on different width wheels.
I have 32 by 11.5 on 15X8 rallys on a stock suspension with no rub what so ever. You can probably get away with 33's. (Watch it though, different brands actually measure out different. I have BFG All Terrains.) |
alright thanks alot this is helping me tons
Got Big Block?
33x12.5x15 on my 15x8 rallies. stock ride height, no clearance problems but I wish I had about 2 1/2" lift for looks.
"Experience is what you get when you didn't get what you wanted." |
#13 |
I would like to have the 2.5" lift also for looks. (Not sure how I will sneak that one past the wife.) BTW I read a good article along time ago why the front ends are wider than the back. The reason was these trucks (and some older cars) would steer and handle much better. Seems if you made them the same width the back end had more of a tendency to want to switch places with the front.
