Old 06-09-2002, 09:58 PM   #1
Low69CST
Front valance additions
I've seen trucks before that have the plastic front valences below drafted over to 67-72's. I got the front fenders and grill in my truck. As soon as I get my bumper brackets put on i'll hang the bumper on and try to buy one of these valences. My dad has a 87 4x4 and it looks like the valence on it is wider than the one on this 2wd. I'd like to get the widest one possible so it'll be closer to the ground and give my truck that sealed off look against the road. Also, where the 2 fog lights are at is about where I want to put my 2 cold air induction vents. Ramairbox.com has kits where you put ducts in your vehicle and run air hoses up to a special air cleaner housing. I think this will be a neat and different air cleaner set up.
The pic was posted by someone on the board, nice lookin truck, I had to steal it
Well, the pic is too big to upload, i'll have to put it in after I get it on my server
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-09-2002, 10:08 PM   #2
Low69CST
Old 06-09-2002, 10:20 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If this is gonna be a daily driver, that may be too low (if your truck is lowered it will be). If you suck up water in there (deep puddles) you'll end up with busted pistons.
Old 06-09-2002, 10:46 PM   #4
Low69CST
Its not gonna be a daily driver. It'll be at a level close to that of a corvette. I've been in thousands of those cars and driven them everywhere. They will scrape the ground but never seen one busted off. I've thought about the water issue. The air duct is gonna have about a 3.5ft. elevation change going to the carb. The valance is gonna be rear of the bumper which will help cover it up. Also, water is pretty heavy, to push it all the way up that air tube you'd have to be runnin around 70-80mph I think. Also my tires are gonna so wide that high speed in the rain isn't gonna be possible. If it starts being that big of a problem, i'll just get a 14" air cleaner and switch tops so it'll suck air out of the engine bay like any other air cleaner. If you see this truck runnin in a huge rain storm, call the cops, this b*tch is stolen!
Old 06-09-2002, 11:56 PM   #5
Longhorn Man
Cool, just tossing out ideas. I saw a home job on ram air last night at a cruise in.
Old 06-09-2002, 11:57 PM   #6
Longhorn Man
And the rest of it...
Old 06-10-2002, 12:19 AM   #7
Blue_71
Bloo
Blue_71's Avatar
i think if you heated the center of a 88-98 ones and rebent it a little less of a V it would work, im one of the guys who didnt liek it at all the first time you mentioned it, but now im going to try it on mine, lol
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 06-10-2002, 12:30 AM   #8
Blue_71
Bloo
Blue_71's Avatar
meant to mention, would you want to buy the peice if it does work? i dont want it, i was just going to try it to see for people who mihgt.. its got the tow hook holes
1989 Chevy K2500
Old 06-10-2002, 08:30 AM   #9
Low69CST
Thanks for the offer, but nah, I think i'm gonna check with the local Chevy dealer and get a new one. I wanna get one that hasn't been scraped or cut up.
Blue, am I starting to rub off on you???
Another 6 months and you'll be rollin on dubs! hahaha
Old 06-11-2002, 11:00 PM   #10
Blue_71
Bloo
Blue_71's Avatar
lol, you must be, cause i put that thing on my truck, and its not going NOWHERE now, i love it!!! had to cut otu two sqaures for where the frame is and drill mounting holes, but other then that no work to fit
1989 Chevy K2500
Old 06-11-2002, 11:03 PM   #11
Benrs86
Benrs86's Avatar
blue...pics?
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 06-12-2002, 12:07 AM   #12
Low69CST
Man, I'm glad you liked it. I climbed under my dad's 87 tonight and looked at how it was mounted. I can probably rig some type of brackets off the frame and front bumper mounts to bolt this thing to. I think i'm gonna order one at the GM garage tomorrow.
Old 06-12-2002, 12:19 AM   #13
Blue_71
Bloo
Blue_71's Avatar
ill get soe pics when i get my fender back on, i think you should get a 88-98 one, mine went on perfectly and even lines up where its going to straight under the fenders. if you want to wait a day or two ill take a pic of the side ive got a feder still on and then you can decide weither you want a 87 type or a 88-98 (mine come off a 95-6 but its identical to the one on the 89, so im guessing there all the same for that body style) now to just fix some kind of air duct or tow hooks or somethign in those holes
1989 Chevy K2500
