Old 04-13-2005, 10:57 AM   #1
bagged74
its just $$$$$
bagged74's Avatar
lights to gauges???help please!
does anyone know what you have to change to go from an idiot light dash to a gauge dash in an 86 C-10? I figure the sending units are probably different, but is the wiring different also? Any info would be appreciated.
bagged74 is offline   Reply With Quote
Old 04-13-2005, 12:40 PM   #2
60-66 Nut
Professional Beer Tester
I've done the swap, but it's been many years ago, and I can't remember all the details. The sender units are definatley different, the engine harness should be the same but I think the harness plug may be different on the back of the cluster. Maybe someone else can tell you for sure. I guess if you wanted to, you could change the plug along with the cluster, you'd just have to be sure to put all the wires back where they belong. Best of luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 04-13-2005, 03:51 PM   #3
75stepside
*Proud Member*
75stepside's Avatar
instead of changing the entire harness plug, you can probably just use a tiny screw driver and move the pins around as needed... if i can get to my painless manual, i could post the schematics of each guage cluster plug...
75stepside is offline   Reply With Quote
Old 04-13-2005, 10:42 PM   #4
tkeduk8r
tkeduk8r's Avatar
Ive done htis swap in my 74, and even though i cant find my schematic anymore it was relatively easy to do... All you need to do is compare the circuit sheets on the back of each panel and compare which wires go to which gauge... and heres a hint to, you should use a newer cluster with an electronic oil pressure gauge and voltmeter... now each gauge needs a hot and a ground to work... the lights have their own bus to work also.. so just find your black wire (ground) from you harness, locate where it plugs into the cluster and follow the bus around, that wil give you your grounds, then the other bus on the gauge is the sending unit hot.. sounds confusing but its really not... then when your done figuring out what goes where, then start switching wires around in your harness connector with a small jewelers flat head screwdriver... i did mine in an after noon and it worked out slick, just take your time and have patience, all those busses start to lokk the same after a while... if you have any questions ill help you out the best i can..
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 04-14-2005, 12:14 AM   #5
bagged74
its just $$$$$
bagged74's Avatar
Thanks for the info guys. And if any of you can find that schematic, that would be greatly appreciated also.
Old 04-14-2005, 08:36 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by bagged74
..... a gauge dash in an 86 C-10? .... Any info would be appreciated.
Hmmm? What 86 C10 are you working on? It can't be yours cause you don't have one....right?
Old 04-14-2005, 10:42 AM   #7
bagged74
its just $$$$$
bagged74's Avatar
well maybe I do, but I'll never tell. Actually I do and I hope to be able to drive it sometime in the near future, but I cant stand those idiot lights. I have two gauge clusters and a whole harness if needed, I jsut have to figure out exactly what to do.
Old 04-14-2005, 10:45 AM   #8
TrainD5115
North Coast, baby!
TrainD5115's Avatar
You could go with updated gauges mounted in a stock (modified) bezel also. It might be easier than trying to work on the wiring harness.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 04-15-2005, 01:51 AM   #9
bagged74
its just $$$$$
bagged74's Avatar
I have gone that route before with a set of Autometers. They are very cool, but i'm not looking to spend that much on the gauges in this truck.
Old 04-15-2005, 11:02 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, then maybe I could get some pics of the truck that you may or may not have....
