Time for a brake job.
The rear brakes are squeaking and the fronts are pulsating pretty bad. I took a look and the rear wheel cylinders are not looking to good and I know that the front needs shoes so I decided that I am going to replace it all. Drums, shoes, wheel cylinders, adjusters, new hardware kit and rubber brake lines. Fifure I will start with the front first and and work my way to the right rear so that when Its time to bleed it out then its just a matter of not tighting up the bleeder valve and away I go.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Good idea to only disassemble one at a time too, so you have the opposite side as a reference and keep in mind that the right side is a mirror image of the left or vice versa. Tighten all bleed screws and only open one at a time when bleeding. Start with the proportioning/combination valve bleeder and work your way to the furthest wheel or the right rear 'till fluid runs clear and all air is evacuated.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Definately going to do one side at a time. If I have time tonight I will do the rears. I will start with the left rear and go back to the right rear and park it. I will do the fronts the the next day and once done I will start bleeding the brakes. This way I wont have to bleed them twice.
Yes I am referring to the bleeder screw on the prop valve (my 72 has it). I just realized you have a 67/68, I'm not real familiar with those years so I don't know if they came equipped w/that bleeder.
Man I love the 67/68 front clip and small rear window. ![]()
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() Last edited by Sweet72; 04-13-2005 at 09:47 PM. Reason: add comment |
what a difference...
i did mine with the help of a buddy. amazing difference. it was pretty affordable too..
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
I didnt have as much time on it as I would have liked last night. Daddy duty took over
