Old 04-13-2005, 03:36 PM   #1
TheSwede
33"s on a not lifted stepside -89 ?
Can i have 33"s on my stepside 1500 1989 its not lifted!!
do they rub?
i have got 15x10" Shelby Slotmags
im from sweden and i have a Chevy 6-fot 4x4 8-lug -74
TheSwede is offline   Reply With Quote
Old 04-13-2005, 03:43 PM   #2
bringit
I have been told by shops that you need atleast 2 1/2" so they dont rub. Like a body lift of small suspension lift.
85 chevy K10 350 crate, headman headers, street avenger carb, accel distrib , rebuilt 700r4, on 33" Super Swamper TSL's, 4 inch Pro Comp lift, shocks, and steel braided brake lines.
bringit is offline   Reply With Quote
Old 04-13-2005, 04:19 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I think they will rub, but not completely sure. I believe you would need to do some major fender hacking or get a small lift or body lift.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-13-2005, 04:26 PM   #4
griesel72
griesel72's Avatar
the height is ok, but the width will kill you, if they are 33 12.50's. They will rub when you turn, and bend the heck out of your chrome trim around your wheel openings. I ran 285's and 295's on my 89 4X4, and had little trouble. The 285's measure out as 33 X 11.0 inches.
Good luck
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 04-13-2005, 04:44 PM   #5
TheSwede
thanks for all posts!
how do i easy lift it?
in the rear its just to put some metalblock between leaf and axle..
but in the front? maby 2" i dont wanna buy any kit. usa is so far away... /=
Old 04-13-2005, 04:54 PM   #6
1FaastC10
1FaastC10's Avatar
to fit 33 x 12.50s on 15x10s on a 88+ truck, and no lift kit, you have only one other choice. hack the fenders. you MIGHT be able to get away with a 33 x 10.50 on a 15 x 8 rim and the right backspacing, but its doubtful.
1FaastC10 is offline   Reply With Quote
Old 04-14-2005, 07:53 AM   #7
TheSwede
ok... crap.. i dont wanna lift it right now...
31x10,5 ?
32x10,5 ?
do they fit? anyone know?
would love to see some pics of stepsides with 31-33"s !
Old 04-14-2005, 08:53 AM   #8
88Jimmy4x4
88Jimmy4x4's Avatar
You could put 2" add a leafs in the front and rear springs, that would give you enough and they are only like $55 a set. Also, if youwent with 15x8's instaed of 10's they would fit much better and give even more clearance.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-14-2005, 01:03 PM   #9
uncle_handsome
Uncle H. is this cartoon
uncle_handsome's Avatar
89 trucks don't have front leaf springs without a solid axle conversion.
I hear people run 32x11.5's easily on unlifted trucks. BFG makes a 33x9.5"-15 in a/t and mud if you want the ground clearance.
BTW You can fit a 33x10.5"-15 tire on a 15x7" wheel. That'd make it almost half an inch narrower than if mounted on a 15x8".
uncle_handsome is offline   Reply With Quote
Old 04-14-2005, 05:47 PM   #10
TheSwede
this are the sizes i can choose from
http://www.hjulhandla.nu/4x416.htm
http://www.hjulhandla.nu/4x4van.htm
would really like to have 15x10" cuz the look soo cool
Old 04-14-2005, 07:37 PM   #11
1FaastC10
1FaastC10's Avatar
the 15 x 10s arent gonna cut it. that's where most of your problem lies. they're too wide.
Old 04-14-2005, 10:18 PM   #12
Hoods69BadBowTie
Chevys Kick A$$
Yeah, I think those 15 x 10s are still going to be too wide.
-Later
-LATER
Old 04-15-2005, 10:00 PM   #13
uncle_handsome
If you want a fat tire look, BFG makes a 325/60R-15 in all-terrain and mud terrain that is 30.5" tall and almost 13" wide. That tire might fit on an unlifted truck since it's about the same diameter as a stock tire. (Since it's an unusual size it'll cost you a little more than a 33/12.5-15)
Other companies also make short, fat mud tires like 29x11.5, 30x12.5 etc. If you want to run the 15x10 wheels you'll need a shorter, fat tire.
Old 04-16-2005, 03:08 AM   #14
TheSwede
tried a 32x10,5-15 spare tire today and that was no problems...
but the rim was 15x8"
tried the 10" rim on without the tires and it was 4" out from the fender....
maby 8" is enough
i wanted 10" cuz i had a 75 blazer with 15x10s...but it seems the older ones have more space for wheels...
posting pics on stepside with spare tire and blazer 75 with 15x10
Old 04-18-2005, 02:22 PM   #15
88Jimmy4x4
88Jimmy4x4's Avatar
DOH!!!, didnt even snap to the year.
You can crank your t-bars up to gain front height, or install the ford keys for a couple inches, then blocks or AAL in the rear or BL, but your not gonna fit 33's on an 89 without some kinda lift and still have the truck offroadable without trimming metal.
1991 GMC Jimmy 4x4
Old 04-18-2005, 11:00 PM   #16
1FaastC10
1FaastC10's Avatar
33s will fit real easy with a 3" body lift, as for being "offroadable", until you put a straight axle in the front, its not going to be very offroadable anyways. IFS was designed with one thing in mind, and that is on road handling.
Old 04-19-2005, 03:33 PM   #17
TheSwede
ordered tires today..
31x10,5-15
i hope they are gonna fit on my 15x10 rims..
Old 04-19-2005, 03:36 PM   #18
TheSwede
i had the body lift in mind but its to much work at the moment..
Old 04-19-2005, 06:11 PM   #19
1FaastC10
1FaastC10's Avatar
31x10,5-15
good luck getting the beads seated. keeping them seated will be easy compared to getting them to seat in the first place. i wouldnt go any wider than 8" with a 10.50, 6" or 7" is probably a way better idea.
Old 04-26-2005, 02:13 AM   #20
TheSwede
got the tires this weekend!! =)
looks like this! and it dosent rub!
