Old 04-13-2005, 04:00 PM   #1
Crazy-J
Crazy-J's Avatar
Covering the rear of the cab after fuel tank removal
Hi,
What are you guys and gals doing with the rear inside part of your cab after you remove the tank to cover it up? Just putting carpet in or is there a company that makes something I can cover it up with that looks decent?
If you have pictures please post them up too.
Crazy-J is offline   Reply With Quote
Old 04-13-2005, 04:05 PM   #2
ChevyDude
I am going to fashion a piece of 5/8" particle board, round off the corners with a router and cover it with some black vinyl leather looking material.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 04-13-2005, 04:06 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
I picked up some tile backer board and put carpet on it. I left extra carpet on the edges so I can go around the sides of the cab to the door frame area.
Here is a pic of it - not secured yet.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-13-2005, 04:44 PM   #4
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Great place to mount some woofers/speakers and an amp when you're done. Looks good YJ.........Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 04-13-2005, 04:57 PM   #5
Bowtiefreak
Bowtiefreak's Avatar
You can also get a piece of carpet pre-cut to fit that area from Tim Christian. Thats were I got mine a few weeks ago.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 04-13-2005, 05:04 PM   #6
RON WOODGEARD
Resident Young Old Dude !
I'm going leather interior.. ( one of these days) And not sure if I want to cover this in Leather or Carpet.
RON WOODGEARD is offline   Reply With Quote
Old 04-13-2005, 05:22 PM   #7
Crazy-J
Crazy-J's Avatar
Thanks, I like those ideas. I'm going to have to do something like that.
Bowtiefreak, how much was the piece that's made by Tim Christian and how did you like the quality of it?
Thanks again.
1972 Chevrolet C10
1969 Camaro
Now filled with GOLDOLINE!
Old 04-13-2005, 05:23 PM   #8
mocwon
Keep On Truckin'
mocwon's Avatar
I covered the entire inside back of the cab with Dynamat look-a-like. Put strips of foam in the recesses. Then, 1/8" Masonite glued up with Liquid Nails across the entire back cut out to fit exactly. Next, fabricated 18 gauge pieces at the cab corners for speakers rolled at the top corners to blend into the cab back panel and attached them to angle iron flanges welded to the cab at the piller and cab back. Then, put a piece of 1 X 4 between the cab mounting hole brackets on the floor and a short piece of 1 X 4 on the outside ends with a taper to match the angle of the floor. Ground down the cab mounting bolts, then glued a piece of Masonite across the entire width of the cab to where the angle drop offs start on each side. Finally, I covered the whole shebang in one piece of trunk liner material used in late model vehicles. It's all flat, smooth and updated looking.
Here it is during the mock up. I'll try to get some "after" pictures this weekend.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 04-13-2005, 05:29 PM   #9
thisolechevy
I built a custom sub enclosure to fit my Digital audio 15" sub and hold me 2 VR amplifiers. It hits good and covered the area where there is no carpet, we are still in the process of tuning the setup so the box isnt covered in carpet yet. Once its done I'll get pics.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 04-14-2005, 11:18 AM   #10
Bowtiefreak
Thanks again.
I beleive it was $60. It fit fine and the carpet is actually made by "Trim Parts"
The only thing about it tho is that its not designed to cover up the top gas tanks humps were the tank gets bolted down. You can make a piece out of board like the other guys did in previous posts and then cover it with the supplied carpet. The carpet is sent a little long so you can cut it if needed.
Old 04-17-2005, 08:23 PM   #11
mocwon
Keep On Truckin'
mocwon's Avatar
Here's a few shots of another method
Just Passin' Thru
Old 04-18-2005, 01:32 AM   #12
brad juan
there is a company called rod doors that makes a ABS plastic piece that I believe snaps to the body and you use headliner adheasive to glue carpet down to it, its a nice way to do it. they have a website, I think it is www.roddoors.com, try them out, they are in Chico CA
1972 chevy C/10, with factory air, SWB, 350,700r4, lowered 3 and 5.
brad juan is offline   Reply With Quote
Old 04-18-2005, 10:12 AM   #13
Tim240Z
Tim240Z's Avatar
Sorry to highjack this thread, but for you guys that have removed the tank, have you all welded up the filler neck hole on the cab body? I would like to do something less permanent. Is there a rubber block-off grommet available, or something similar?
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 04-18-2005, 10:38 AM   #14
Yukon Jack
Post Whore
Yukon Jack's Avatar
Mocwon - that turned out great.
Tim240Z - I haven't seen any type of block-off grommet - mine is welded up.
Old 10-03-2011, 09:40 PM   #15
C10NEWGUY
Re: Covering the rear of the cab after fuel tank removal
check this out.....
http://67-72chevytrucks.com/vboard/s...d.php?t=250995
1977 Chevy C10 RWD long bed
C10NEWGUY is offline   Reply With Quote
Old 10-04-2011, 10:02 AM   #16
Andy4639
Old member
Andy4639's Avatar
Question Re: Covering the rear of the cab after fuel tank removal
I bought a plastic gas cap and drilled holes on the threaded end and did the same thing as the bolt but used tie raps to secure it before I had it welded up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
