Old 04-13-2005, 04:16 PM   #1
r0lf-
Hotwheels?
r0lf-'s Avatar
LCA Bushings, how hard to replace?
So My LCA bushings are pretty much shot, no suprise seeing how its almost a 30 year old truck. Am I gonna be able to replace these myself or do I need a shop to do it? My manual for the truck says have a shop do it. Input?
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 04-13-2005, 07:03 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
This will explain how I rebuilt my frontend. It's not real hard to do but can get annoying at times if you let it. Depending on how handy you are with tools, it might just be within your scope of things to do yourself.
http://www.73-87.com/7387garage/chas...n/frontend.htm
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-14-2005, 12:27 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Swervin's guide (as well as his others) are very good articles.
To remove the bushing from the LCAs, you could use a drill to 'drill out' the rubber bushing (between the metal sleeve and metal insert). Then, use pliers to wrestle the rubber bushing away from the metal sleeve and insert. Once the rubber bushing is removed, the metal sleeve can be deformed using a hammer and punch and then removed. Then remove the metal insert from around the LCA shaft.
OEM bushings (rubber) are one piece vs the three piece urethane bushings. This makes it a bit more difficult to install. Install the first bushing using a press/vice as mentioned in the article. Then, insert the LCA shaft (lubed) and install the second bushing. A different adapter is needed to press in this bushing around the LCA shaft. You may want to take your disassembled LCAs and have a shop press in the bushings.
While you have everything apart, you may want to replace your ball joints at this time, especially if they're worn.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-14-2005, 11:48 AM   #4
elvis50138
elvis50138's Avatar
Swervin... fabulous write-up. I actually was looking for something like this yesterday in the FAQ as I plan to do this in the near future. Thanks.
elvis50138 is offline   Reply With Quote
Old 04-14-2005, 02:34 PM   #5
r0lf-
Hotwheels?
r0lf-'s Avatar
Thanks a bunch swerve! Thats exactly what I need. Are you using energy suspension bushings? Thats what im planning on replacing with. Having a loud THUNK everytime I air up is definitely annoying, stupid bushing popping into another position.
Old 04-14-2005, 02:49 PM   #6
Izzy
Trucker.
Izzy's Avatar
It may still do that afterward. With the ART front mounts my 83 made that sound because the bag is somewhat twisted from when it's laid out to when it's lifted to ride height. Used to happen around 35-40 when raising it.
Izzy is offline   Reply With Quote
Old 04-14-2005, 03:01 PM   #7
r0lf-
Hotwheels?
r0lf-'s Avatar
Hrmmm, well it happened with my springs too, when id put the truck up on jacks then lower it back down, it would totally THUNK into place finally. Is this the same with the springs seating or something?
I have SD uppers and cups if that matters.
