The LuvShack Garage
NO IDEA, CAME IN THE BOXES AND BOXES OF GOODIES SHIPPED W/ "GQ"
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
67 is sold
alternator bracket ?
No,I DON'T have Tourett's
altenator bracket?
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
whoaaaa........deja vu
Questionable
alternator relocation bracket?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
its all about the +6 inches
A/C bracket, a big block alt bracket maybe? it isn't a small block alt bracket...not a stock one anyways.
#7 | |
67 is sold
Nothing fits but the oil
Power steering bracket??
Land of the free Because of the brave |
The LuvShack Garage
WOULD WE ALL AGREE TO DISAGREE THAT IT'S NOT A DRIVERS SIDE BRACKET
Catchy title goes here..
![]() Join Date: Mar 2002
its one of them thingamabobbers that attaches stuff to other things
Questionable
I swear it's an alternator bracket - I thought it was the one most people use to relocate from one side of the engine to the other, I just can't seem to find a picture. :S
#12 | |
The LuvShack Garage
W/ THAT SAID, IT IS A PASSENGER SIDE BRACKET RIGHT ![]()
#13 |
Smog pump bracket? I'm just throwing it out there, I have no idea what it is but it looks familiar.
#14 | |
graphic designer
#15 |
20' Daredevil (Ret)
![]() Join Date: May 2003
That exactly matches my factory upper A/C compressor bracket.
#16 |
see post #9
SB upper AC pump bracket. I think I have seen one on a 71 and then this one in pics. 71 I saw was stock. taken from post #9 in link
http://207.44.196.117/vboard/showthr...ht=small+block what do I win?
Bob |
#17 |
darn
1 minute too late for prize, should haver just posted the link instead of the pic!!
Bob |
#18 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
I back these guys on this being the upper a/c bracket. It is normally the one missing on a/c trucks. It also tends to be the hardest of the brackets to find, and most expensive. If I remember right, the top bolt hole bolts to the intake and the bottom bolts to the short water pump.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#19 |
It is most definately an alternator bracket, i should know I am rebuildiung my motor and I had to get a new one of those to hold the alternater on with.....
1985 Chevrolet C-30 454 1-TON Dooley 1969 CHEVROLET CST-10 PICK-UP Good memories 1999 Chevrolet Z71 Ext. cab 5.7L Good Memories With a quart of oil, and a gallon of gas, she won't let no other car pass!!!. ![]() ![]() |
#20 |
A/C bracket. Just like Cheyenne10 shows in his pic. Passenger side mount A/C.
#21 |
The LuvShack Garage
Ok, Now I Am Really Confused, So It Sounds Like I Need It, But
In The "LMC Bible" It Does Not Show It In The Pic's, I Have All The Other Brackets, So Does It Work W/ The Others Or Do I Need To Remove One Of The Others For It All To Work, Help ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 04-13-2005 at 09:24 PM. |
#22 |
SWB 4x4 Collector
No, you won't have to take them apart. You may have to notch that long skinny piece that bolts to the side of the block though for your headers. Most people do. I heard you maybe able to buy something at o'reily's to fix that though without cutting. You might look into that first.
#23 |
SWB 4x4 Collector
hope this helps.... not 100% sure... about the bottom hole for the big brkt. I don't have my truck up here at school to tell you.
#24 |
20' Daredevil (Ret)
You need it and the others you showed. It's just like Cheyenne 10's pic, and it bolts on like super4x4 says. The (upper) waterpump bolt goes through the upper bracket first, then through the thick cast bracket in your lower pic. The other hole ( a couple inches or so away) in the thick casting uses the other (lower) waterpump bolt.
Hope this helps, and I sure wish I had a digicam. That A/C bracketry is a bit of a Chinese jigsaw puzzle.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 04-13-2005 at 10:59 PM. |
#25 |
It's a catastrophic success.
![]() Join Date: Jan 2003
Passenger alt brackets
