Old 04-13-2005, 08:47 PM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
HELP! Need Saginaw 3 spd part!!!
Does anyone have an imput shaft out there for a saginaw 3spd. I have extra's, but I need one for a piece of equipment I made years ago and it has to have one a diameter of .885" between the splines for the clutch and the trans case ball bearing for a carrier bearing setup I made then. If anyone has one give me a shout, PLEASE!
Thanks,
TP
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 04-13-2005, 09:44 PM   #2
Harold Shepard
I have a three speed I took out of a 69 1/2 ton, it has the input shaft -the retainer is already gone- tell me what I need to get out and I will be happy to trade or sell you the thing. Just let me know. Harold
Harold Shepard is offline   Reply With Quote
Old 04-13-2005, 09:46 PM   #3
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
I have a three speed that might be right. Its a 10 spline with 7 bolts on the cover and 21 inches long. That the right one?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 04-14-2005, 06:35 AM   #4
TP from Cntl PA
I'll take a picture when I get home this afternoon of what it looks like.
Thanks guys,
It is appreciated!
Old 04-14-2005, 08:21 PM   #5
51 68CHEVY
I Have One From A 1971 3/4 Ton P.u. It Had A 307 3 Spd Trans. A'm Located In N.j Atco By The Dragstrip.
51 68CHEVY is offline   Reply With Quote
Old 04-14-2005, 09:33 PM   #6
TP from Cntl PA
Here is what is left of it...........I bent the out put shaft on it. Then tried to re-weld it together after facing the parts on the Lathe(Hillbilly engineer)..........In total failure
I need just this part, which is all one piece. I'd like to have the area between the cut and the splines where the clutch would mount .885" in diameter as I have a sleeve that splits in half for a carrier bearing I machined, but as with anything else, will take what you have so if you have one let me know the price. Like I said, it would be nice to have one .885" in diameter, but..........
Yell on this thread and I'll contact you through email.
TP
Old 04-14-2005, 09:44 PM   #7
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
i have a 3 speed here in pa....you can have the whole trans cheap...
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 04-14-2005, 10:02 PM   #8
TP from Cntl PA
Would you just want to put that piece out of it and sell me it? I really don't need anymore parts laying around. I have 4 of everything else for a saginaw except the one I need
Old 04-14-2005, 11:20 PM   #9
67ChevyC10Stepside
lol....probably...get me a pic of what you need.....are all the 3 speeds for these trucks saginaws? make sure i have the right thing first.
Old 04-14-2005, 11:20 PM   #10
67ChevyC10Stepside
also how much you payin?
Old 04-15-2005, 07:05 AM   #11
TP from Cntl PA
I don't know what it is worth? What the value to you?
I'll get you a picture of the Case tonight, I'd imagine they all use that same imput shaft.
Old 04-16-2005, 07:07 PM   #12
TP from Cntl PA
TTT
Someone MUST have one?????????????
Old 04-16-2005, 07:58 PM   #13
67ChevyC10Stepside
i need a picture.....
Old 04-16-2005, 09:00 PM   #14
stelth2002
stelth2002's Avatar
No, not all 3 speeds are the same in these trucks. There are 2 or 3 different ones. I believe you can identify them by the bolts on the side cover. I have the tranny that has 7 bolts on the cover.
JT
Old 04-16-2005, 10:46 PM   #15
stan79chevy
stan79chevy's Avatar
i have a 3 speed trans
its out of a 77 3/4 ton 4x4. if that is the right kind ill get the part out of there that need in trade for a np205 tourqe mount.
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 04-18-2005, 01:05 AM   #16
67ChevyC10Stepside
are you going to show me what you need?
