Towing Options: moving from MD to NM
Hey guys,
I just got orders to Albuquerque, NM. I presently live on Andrews AFB, MD and I only have 3 weeks to decide how I am going to get my 72 from here to there. I have a 2004 TrailBlazer with 5300lbs towing capacity and factory hitch (reese style). I was thinking of several ideas: (1) tow dolly, (2) tow bar, (3) car hauler trailer, or (4) drive it 13 hours to Florida and leave it with my brother for 3 years and not touch it. I need your thoughts guys. Ideally, I'd like to buy a used trailer and haul it over to Kirtland AFB, NM. However, I'm not sure I want to use a dolly or car trailer. I could rent, but I figured I could probably buy just as cheap as I could rent for a 3 day drive. Does anyone have any ideas? Please drop me a message or respond with serious remarks only. I appreciate it. Thanks, Clint
Primer Gray 72 LWB w/a 307 ![]() |
Son Of Gravel Man
I'd probably just price shipping it.
Moving that far is a PIA. |
its all about the +6 inches
When i went from Fort hood Tx to Columbus Ohio I hardly even noticed the truck on the tow bar behind me...even when it shredded a tire I didn't notice it.
![]() If you have any mountian passes between point a and point b...I don't recomend a tow bar onless you are driving something huge. (like a 24 foot moving van) however, if it is fairly flat ground...a tow bar is hard to beat if you are a man with common sence. |
The truck should have no problem towing that little ol`Trailblazer to NM.I`d use a dolly,save the extra weight of the trailer.
Big Block
Tow dolly
I used a tow dolly to tow a 55 Chevy 2 dr Belair from Ill. to NC. I towed it behind a 2wd 96 Chevy EXT Cab. I had no problems even thur the mountains of WV. B.B
Thanks for your info. guys. I am using the Trail Blazer to pull the 72. I know I would have to disconnect the drive shaft using either a tow bar or a dolly. Does anyone know anybody in the Washington D.C. area or nearby that has either setup for sale?
if you use a car dolly, make sure you measure the outside tire width to fit the dolly....some dollys are not made for these trks.... just my 2 cents worth.....and if you rent a car trl, sometimes the trk dont fit those either.....
![]() Join Date: Jan 2005
Second the idea of making sure the tow dolley is wide enough. I went down to San Antonio with my 2004 Dodge Caravan fully expecting to rent a U-Haul tow dolley. Picked up the dolley and it was too narrow for our trucks (68 c-10 Short Stepside). Luckily the guy next door had a used tow dolley for sale for $400. Made it back to Tusla. Since then I have pulled a 71 Short Stepside from Eastern Kentucky and a 4x4 from Northern Louisiana. Tow dolleys are great since you are mainly pulling and not carrying, like with a car trailer. The only bad thing about a dolley is don't try backing up with them. Dolley goes one way and the truck goes the other. So plan your parking.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
If your truck is a stick shift, you can leave the drive shaft hooked up.
computer illiterate
I have used a tow bar before to pull from nebraska to illinois in the winter (had a snow storm that day) and it did great. If I where you being from up north unless the body is absolutely cherry I would sell it and by a nm RUST FREE TRUCK and work on it.
72 2wd blazer 72 swb 4x4 |
Let the Military pay to move your truck, and drive the Blazer, or are you wanting to pocket that fat travel check your going to get.
