Old 06-09-2002, 11:58 PM   #1
Primer_72
User and Abuser
Arrow Urethane Bushings
How can you quiet down polyurethane suspension bushings?? I put lower control arms on my 99 Sierra and the noise really bothers me....It's embarassing really, kinda like the tailpipe bouncing off the rear-end on every bump I hit...
RIP....
'99 Sierra 2x
'93 Sierra 4x
'72 C-10
Back in business: 68 C-10 lwb
Primer_72 is offline   Reply With Quote
Old 06-10-2002, 10:48 AM   #2
slam33
slam33's Avatar
I used the grease that came with the bushings, all of it and I don't get a sound out of them. It's a special grease for those bushings
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 06-10-2002, 08:55 PM   #3
Primer_72
User and Abuser
All mine came with was threadlocker...Did you put the grease in the zerk or was it for the inner sleeves when you assembled it? I just used wheel bearing grease on the sleeves and chassis grease in the zerks...
RIP....
'99 Sierra 2x
'93 Sierra 4x
'72 C-10
Old 06-11-2002, 10:01 AM   #4
slam33
slam33's Avatar
it's a special grease for urethane, very tacky stuff. I put the stuff anywhere there would be contact, inside, outside and the ends. You can get the stuff from Energy Suspention. Check there site
</A>
Old 06-11-2002, 03:41 PM   #5
busterwivell
It's messy stuff, but it works.......I don't envy you taking it all apart to grease it up, but that's the only way the noise will go away.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 06-12-2002, 11:44 AM   #6
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
used to have poly bushing in my olds and I had to grease them at least once a year to avoid squeaks
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 06-13-2002, 11:09 PM   #7
Primer_72
User and Abuser
Well I'm putting tires on it tommorow so I'll check it out while its on the lift...Wont be that bad taking it apart, a spring compressor makes it alot easier. Wish Godfather or DJM woulda mentioned that before I put it all together...
RIP....
'99 Sierra 2x
'93 Sierra 4x
'72 C-10
Old 06-13-2002, 11:22 PM   #8
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
when did you get the 99 GMC?!
68SWB4x4 is offline   Reply With Quote
Old 06-14-2002, 11:25 AM   #9
68 with 350 TPI
68 with 350 TPI's Avatar
I know this is going to sound bad but get some dirtbike chain lube.
The stuff is supper tacky and will say put.
Stuff works better than anything I have ever seen.
And here is a name brand to get...Spectro(golden spectro synthetic total tac chain lube for o ring chains)
Get it and the squeeks are gone
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 06-14-2002, 03:27 PM   #10
batboy
batboy's Avatar
I haven't tried poly bushings in any of my trucks, but I have them in my hotrod V8 Fiero. Like was said, usually a special grease (maybe a moly grease?) comes with the poly bushings. What I did (was told this by several other people who have done it) was to take a bare hack saw blade and cut a shallow groove on the inside hole of the poly bushing. Then grease the "H E double toothpick" out of it. This groove traps a supply of grease and keeps the bushing lubricated for a much longer time than normal. Those poly bushings are a little squeaky and noisy unless they are well lubed.
batboy is offline   Reply With Quote
Old 06-17-2002, 10:03 PM   #11
Primer_72
User and Abuser
I got the 99 about a month and a half ago.
Guess I'll have to go find some of this stuff at the ATV shops....Gonna shoot some lithium grease on em tommorow cause its really buggin' the sh*t out of me. Hopefully that'll work then Ill put some of that tacky stuff in the zerks. I really dont want to drop those control arms again, they were a real b*tch....Thanks for the advice...
RIP....
'99 Sierra 2x
'93 Sierra 4x
'72 C-10
Old 06-17-2002, 10:55 PM   #12
68 with 350 TPI
I think that you will like the chain stuff I spoke of.
I have tryed just about everyhing and that worked the best for me.
