04-14-2005, 01:15 AM | #1 |
Front locker hub question
May be a dumb question but I am curiois. When you have manual locking hubs what happens if you had them locked but the transfer case was in 2 wd? Would it wear or mess up anything?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
04-14-2005, 01:27 AM | #2 |
No. I have a 86 k5 blazer and I put a set of Warn hubs on it. I e-mailed Warn about having them locked all the time durning the winter and would it hurt the drivetrain. They said it would not hurt anything except the gas mileage. I ran them all winter like that and nothing happened but the gas mileage did suffer.
art
This is my best friend |
04-14-2005, 01:40 AM | #3 |
blaserman is right. basically, it makes everything inside the front axle spin, and the front driveshaft and front output of the transfer case spins, but it is from the road and not from the engine. I, too, did it in winter when my truck was actually running.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
04-14-2005, 01:46 AM | #4 |
Chevys Kick A$$
I heard it was bad to go above like 30-40 MPH with them locked in but it might be just hearsay bs. I too did have mine locked in for a couple weeks during the winter when it was really icy.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
04-14-2005, 02:12 AM | #5 |
I ran mine up to and over 70mph and did not have any problems, and that was on a daily basics. Bakc and forth from and to work 6 days a week. Like I said prior I contacted Warn on this.
Art
04-14-2005, 06:57 AM | #6 |
A lot of the newer Jeeps and Dodges are built with a part time case and no lockouts from the factory. They eliminated the center axle disconnect a few years ago. Running like that will not hurt a thing.
Tim |
04-15-2005, 06:39 PM | #7 |
Actually, it's a good idea to lock 'em in once in a while if you drive mostly on the street. Keeps the oil circulated and warms it up to evaporate moisture that collects inside things.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
