04-14-2005, 02:28 AM | #1 |
FS: TH350, Rear Sway Bar, SWB Driveshaft, Windshield in Colorado
TH350 Transmission & Torque Converter $40
Rear Sway Bar $10 SWB Driveshaft $20 Windshield $25 The transmission was working great when I pulled it out of my truck to replace it with a 700R4. The speedometer gears have been removed. The rubber bushings on the sway bar are rotted, and one of the rods is a little tweaked (should be easy to straighten I believe the driveshaft came out of a full size sedan. It was installed in my SWB truck when I bought it and worked just fine. The windshield doesn't have any cracks in it. I didn't see any pits in it either. The gasket is torn along the top edge on the part that is inside the cab. Has a new mirror glued to it. Local pick up only (no shipping). |
04-14-2005, 10:56 AM | #2 |
Do you have the axle mounts for the sway bar??? Could you possiably ship to 63344?? THANKS
04-14-2005, 11:13 AM | #3 |
i'll second the rear sway bar if ben doesn't want it.
04-14-2005, 11:43 AM | #4 |
The sway bar bolts to the bottoms of the trailing arms on a coil spring rear end, and the rods on the ends bolt to the bottoms of the frame rails. All of the mounting hardware is included. I don't want to have to track down a huge box for this. I'm hoping that someone local wants it.
04-14-2005, 11:44 AM | #5 |
By the way, the two boxes next to the transmission contain a nearly complete set of internal parts for a TH350 transmission. If anybody wants them, they are yours for free.
04-14-2005, 11:56 AM | #6 |
put me in line for the sway bar.
i survived cancer and kidney stones, but my kids are killing me. |
04-14-2005, 12:05 PM | #7 |
i'll drop out of the sway bar......
04-14-2005, 01:49 PM | #8 |
if there was only a way to safely ship that winddshield!
Ron
Life is full of choices and a Chevy is the best choice. 1990 Chevy SWB |
04-14-2005, 02:02 PM | #9 |
Yeah, the packaging required on a windshield would probably cost more than a new windshield.
04-14-2005, 03:12 PM | #10 |
I like crayons
pj, is that an original windshield ? Regardless, I am interested and in CoSpgs so its easy to pick up =p will pm ya with a phone number.
04-14-2005, 11:21 PM | #11 |
I would like the trans. Is the drive gear or worm gear missing or both? Would you hold it for two weeks until I get down that way? How would you like payment?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
04-15-2005, 01:32 AM | #12 |
Huck PM'd me about the sway bar this morning at 5:02 AM, so he is first in line for it. Looks like he wants it.
04-15-2005, 01:45 AM | #13 |
powell72,
The transmission is yours. I don't mind hanging onto it for two weeks. I pulled both the drive gear and the worm gear out to use on one of my trucks. I have another set I can give you if you want it. I think it is for a 3.07 rear end. You might be better off just buying the correct gears from GM for your application. You can pay me any way you want: personal check, money order, cash, or you can give me 80 rolls of pennies if you want. I"m not too concerned about it. PayPal will work too. |
04-15-2005, 05:41 PM | #14 |
PM sent
