Old 06-10-2002, 12:52 AM   #1
Stano
Stano's Avatar
Question Fan Shroud
I put my new 3 row radiator in today and went to install my fan shroud and it wouldn't fit. The radiator is the correct size and all. I put my engine in the foward V-8 holes in the frame and correct mounts for a small block and all. The only thing not factory is I switched to long style water pump, anyway who has this set up and what shroud fits. I have about 4 in + between fan and radiator.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 06-10-2002, 10:08 AM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Did it have a small block in it before?
Ben
67Fleetsidedream is offline   Reply With Quote
Old 06-10-2002, 11:33 AM   #3
tom hand
CCRider
tom hand's Avatar
What do you mean it doesn't fit? If you are going to use a long water pump you would better off to leave the motor in the six position. The setup you have will not work completey with stock parts you will have to make it work.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-10-2002, 11:34 AM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Two things..... Are you trying to use the 6 cylender fan shroud? You also should go to the short water pump, though I am not sure that is necessary. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-10-2002, 12:37 PM   #5
Mudder
Mudder's Avatar
stano
before u go out and buy a new shroud i have a brand new one down in the garage and i think its for a 2wheel drive truck. i bought it for my truck but its way smaller than the one i have now. ill go out and see if i can find a part# for ya.
Mudder is offline   Reply With Quote
Old 06-11-2002, 12:12 AM   #6
Stano
Stano's Avatar
Thumbs up
Mudder yes check the one you have please. The one I have is about 8 in deep and the one in my 71 is like 5 or so. I need the thinner one. I had the shroud in the truck before when the engine was in the six position. But it came out of a 69 with a long water pump and v8 mounts. Heck I don't know anymore. Thanks for your input guys.
Old 06-11-2002, 12:59 AM   #7
Mudder
Mudder's Avatar
Stano
You just may be in luck. Its 5 inches. Shipping papers says its for a v8 small block without ac. part # 32-2820 from LMC. itll be cheap.. let me know
Old 06-11-2002, 09:08 PM   #8
Stano
Stano's Avatar
What ya got ta have for it? Is it a decent piece quality wise? Let me measure my truck tomorrow or here in a while and will see if 5 inches is enough or too much! That sounded kinky but you know what I mean! Thanks a bunch.
Stano
Old 06-11-2002, 09:48 PM   #9
Stano
Stano's Avatar
Mudder I just went out and measured. I have 3 inches from radiator to front of fan and 5 inches to 2/3 thickness of fan, leaving about 1/3 of the rear of the fan behind the shroud. I think this would work. I also checked my 71 driver and it has the 5 inch shroud also, but with the short water pump setup. and the fan is almost totally behind the shroud. Let me know what you want for it. Thanks again.
Stano
Old 06-11-2002, 10:27 PM   #10
BubbaGreen
FYI: also measure the diameter of the fan you are going to use.
Most newer style motors use a fan/fan clutch assm. The diameter
of newer fans wont fit into the older SBC fan shroud. If I remember correctly, the SBC fan shrould opening is 19" and the
BB shroud opening is 21"
Might want to consider using a BB fan shroud, it has a larger
opening, and isnt too thick. If you run across the 305-V6 GMC
fan shroud, it is even thinner and has the larger opening like the
BB fan shroud.
Good luck.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 06-12-2002, 03:41 AM   #11
Mudder
Mudder's Avatar
Its brand new in box
the price on it was 79.95 and u can have it for 40 bucks. i need to get rid of it.
Old 06-12-2002, 07:46 PM   #12
Stano
Stano's Avatar
Cool! I'll take it. E-mail me at fast_67_chevy_c10@hotmail.com and we will discuss the details or leave me your phone number and I will call you.
Old 06-12-2002, 09:59 PM   #13
Mudder
Mudder's Avatar
stano
just sent you an PM with my number.
Old 06-12-2002, 10:24 PM   #14
PushinPebbles
My dad's 68
PushinPebbles's Avatar
i don't know if this will help but................my 355 is in the Inline 6 holes......it has a long water pump........and i gat a fan shroud from the junk yard off a 75 3/4 ton......................the bottom of it fits snug between the radiater and the rivet or bolt next to it.............on the top side i made 2 - two inch peiced of metal............... the top screws into the rad. support peice..and the other i drilled the plastic and used bolts to connect it to the 2 in peaice.......................i hope this helps.................my overall time in it is 30 mins...................................Jaack
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
