04-14-2005, 12:05 PM | #1 |
Can't kick the addiction!
Lower cost brake upgrades?
What lower cost options do I have for upgrading the brakes on an 82' chevy 1/2 ton swb 2wd? I've already swapped out the power brakes with a hydrobooster setup. Is there anything else I can do?
04-14-2005, 12:33 PM | #2 |
*Proud Member*
rear disc of course... it depends on how extreme you want to go... you could put 13" vented, drilled, slotted rotors at all 4 corners with 4 and 6 piston calipers, stainless steel lines, but i'm sure that would break the budget.
you can fabricate your own rear disc setup for realitively cheap... i did on my '75 project... used camaro rear disc calipers/rotors... had about $200 in it... worked out very well... |
04-14-2005, 01:21 PM | #3 |
Mudslides 'r my specialty
There was a Heavy Duty brake option that you might find on a junker...option code JD5 on my 85 I think.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
04-14-2005, 01:43 PM | #4 |
driving is in my blood
Use pads from a 3/4ton with 13" brakes. They fit 1/2ton calipers the same and cover a little more of the rotor length wise. Have em on my 79 right now.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
